If you guys (and girls) are like me, when you do your repaints you've been using the same waterslide decals for ever.
I'd heard about Pattos Peel and Stick, but stayed with the waterslide, (anything new is just weird and suspicious).
Well I gave some of the peel and stick a try for the first time today, (I wasn't totally happy with the way the waterslides sat on the 9 Camaro, so stripped off the future clear coat and decals and redid them with the P & S) and I'm hooked.
A little bit of soapy water on the place to be decalled, peel the back of the decal, sit the decal on and slide it into place and squeeze the water out by rolling a cotton bud and smoth over with a tissue. So Easy.
The surrounding clear back ground literally disappears. Way more so than waterslides and they are superthin too.
Do yourself a favour and give 'em a go if you haven't already done so.
