Well, here we go :)
The interior is flat tray type, made from a playing card.
MT Resin driver figure, roll bars made from Evergreen rod. Little screen added of course.
I decided to use a different mounting approach. Dave Dobner taught me this trick and it really works. Used some 1/4 square dowel rod and JB Weld. Little super glue in the seam for good measure.
Drilled the mount holes in the side pans, then mounted the body on the chassis. I hot glued it to hold it steady and then used a smaller drill bit and drilled the holes into the wood.
I set the front and rear track width at just under 2 1/4 inches. I wanted that wide look on this car and it worked well enough.
Decals from the scrap bin. Nothing fancy.
All in all this was a lot of fun! Dave made a real nice body and now I finally have that big old sedan in 1/32.
Now for the coupe!
