SCC adjustable front axle blocks
Postby skyler » Sun Jul 07, 2013 8:50 am
What is the best glue I can use to attach SCC's adjustable front axle blocks? Is it JB Weld, Shoe Goo, ICC 2000 tire glue, regular super glue, or something else. Thanks.
skyler
Re: SCC adjustable front axle blocks
Postby super2nr » Sun Jul 07, 2013 11:18 am
I used JB Weld on my Fly Truck.......Sho goo may work if you want to reuse them on a different build
super2nr
Postby skyler » Sun Jul 07, 2013 11:46 am
Thanks super2ner!
skyler
Postby nhdungeonracer » Sun Jul 07, 2013 1:25 pm
We mainly use superglue. I use the thin glue to set them, then use the thicker gap filling glue to secure them.
Postby skyler » Sun Jul 07, 2013 1:38 pm
Thanks Dickie. I have some Poly Zap. Wonder ow that would hold. My real reason for asking was I tried to glue the pod to main chassis plate on Fly classic with JB Weld and it didn't hold. I washed both pieces and scuffed them with 240 grit. Let it dry 36 hours to be shure. BTW, this was the new stuff ( regular, not 5 min ). Seems i've read others complaining the new batch isn't as good.
skyler
Postby skyler » Sun Jul 07, 2013 2:09 pm
Because of Dickies suggestion of using super glue, i decided to experiment. Poly Zap isa super glue recommended for lexan, delrin, nylon, polycarbonate, and rubber. Found a broken chassis and sacrificed an SCC axle block to science. Cleaned both pieces and sanded them with 240. applied one drop of glue to block only. Let it dry about 5 min then tried to brake it off. It broke all right...the chassis. The block stayed connected to the chassis. I think I found some awesome glue for this.
skyler
Postby JML » Sun Jul 07, 2013 6:10 pm
The no-bloom superglues are the best. They won't leave that white stuff nearby, which is redeposited glue. SCC sells excellent non-blooming cyanoacrylates, thin and thick viscosities: SuperGold and SuperGold Plus.
JML
Postby RichD » Tue Jul 09, 2013 7:12 am
We have had a few of the axle blocks come off when a car took a hit. That can ruin your evening if it happens during a race. I would not recommend using Shoe Goo or anything similar. I use a slow setting epoxy because those tend to be the strongest. First I use a small amount to tack the blocks in place, when that has set I add more to be sure that the joints will hold up in a crash.
