1/32 lindbergh model question?
Postby BRP32 » Mon Feb 25, 2013 6:39 pm
Hi guys!
Question about 1/32 lindbergh model kits?
What is the size comparison of the 1/32 lindbergh '34 coupe kit body compared to the revell snap tite 1/32 '34 coupe body?
Are they both approximately the same size or is the lindbergh slightly smaller by comparison?
I have heard the lindbergh 1/32 kits tend to run a bit smaller than the claimed 1/32 scale?
Again any info is very much appreciated!
BRP32
Re: 1/32 lindbergh model question?
Postby waaytoomuchintothis » Mon Feb 25, 2013 6:52 pm
Lindberg is all over the place, especially since they bought some of the old molds from other manufacturers who were attentive to scale. Originally, and as late as 1995, the Lindberg models were crazy small, like somewhere around 1/48, but labelled 1/32. They even had two scales in the same box sometimes. I have a 1995 Chev truck that had a motorcycle to go in the bed, and the truck is 1/42, the bike is 1/55. Their 53 Ford Tudor is around 1/40. (yes, I actually measured it)
Postby Ember » Mon Feb 25, 2013 7:39 pm
Love the example of the Chev truck and bike combo. I knew the Lindberg were bad, but I didn't realise they were that bad.
The biggest advantage I see in the Lindberg kits is that they are fairly simple for novice kitbash experimenting. Unfortunately they are becoming harder to come by over here with most hobby retailers now only stocking the Japanese branded kits.
Postby Derby City Speedway » Mon Feb 25, 2013 7:39 pm
the revell 4-7/8" L 2-1/16" W
lindy 4-5/8" L 2-1/16" W
measurements from fender end to fender end
I don`t know which is closest, but wouldn`t have a problem running them together in a oval race. By the time you get some nerfs on them probably be hard pressed to find much difference.
Last edited by Derby City Speedway on Mon Feb 25, 2013 8:46 pm, edited 1 time in total.
Derby City Speedway
Derby City King
Postby BRP32 » Mon Feb 25, 2013 7:59 pm
Hi Mark!
Your awesome!
That is exactly what I wanted a picture of both side by side.
Like you said they would look perfectly fine running together side by side.
Thank you so much for your help!
I have been toying with the idea of making a few into dirt track racers......
Again I am very much appreciative of your time doing this for me!!!
BRP32
Postby Derby City Speedway » Mon Feb 25, 2013 8:48 pm
no problem Wayne, BTW I posted a wrong measurement they are accually closer than 1st posted. If I would have just read the rule right. :whistle:
edited the post..
Derby City Speedway
Derby City King
Postby BRP32 » Tue Feb 26, 2013 6:03 am
Thanks again Mark!
So both bodies are nearly the same size......
They will make for a nice series of old dirt track racers at Bolton Raceway Park!
I look forward to building a few......
Wayne (Bolton's Speed Shop) :D :D
BRP32
Postby olskoolslotz » Tue Feb 26, 2013 10:35 am
olskoolslotz
"THE Champ"
Postby waaytoomuchintothis » Tue Feb 26, 2013 10:49 am
That's great. I knew some of them were a good scale. We should make a list of Lindys that are good scale as a service for slot car guys. I'm sure we have a good sampling of them. I'll see how many of them I have today just to see. I think the molds that were good that Lindy bought were Palmer and Hawk. There may have been more. Mark may know about this stuff.
Postby oldspark » Thu Feb 28, 2013 7:33 am
Are some of the Lindbergh 1/32 kits multi piece bodies, never liked multi piece bodies for slot cars, I know some of the older ones had this type of body.
oldspark
Postby RichD » Thu Feb 28, 2013 7:44 am
I have the Lindbergh '34 Ford and that is multi piece. Sometimes I tack bodies like that together with a few dots of hot glue just to hold things together . For static models I would then apply model cement from the inside, for slor car bodies I use epoxy.
Postby Reegs » Thu Feb 28, 2013 10:40 am
FWIW: Those kits, originally manufactured by Pyro, where scaled to fit in a certain size box. Sometimes they worked out to 1/32, sometimes not.
The molds went from Pyro to Palmer to Life-Like, then Lindberg.
Reegs
Postby waaytoomuchintothis » Thu Feb 28, 2013 11:27 am
TO FIT IN THE BOX!?!?!
Are you serious or is that a joke?
Postby Reegs » Thu Feb 28, 2013 1:24 pm
No joke.
Reegs
Postby choc-ice » Thu Feb 28, 2013 11:58 pm
I bought one of their Buick Century kits and it's not even equal scale in all directions. A shame because they do some interesting stuff
choc-ice
