So-Cal Speedway upgrade, braid installed! With video!
Plastic Or Wood
All Things Track Building!
Re: So-Cal Speedway upgrade, routing finished!
Postby chappy » Tue Apr 26, 2016 8:00 pm
So when you set the depth for the gains I take it you have to allow for the 2 sided tape, and the thickness of the braid and go for a flush fit?
Postby HomeRacingWorld » Tue Apr 26, 2016 8:13 pm
Yes, and the easiest way is to simply cut and route test slots.
You might see where there are different depths tested. Lay your braid with the tape in the gain and just go by "feel".
If you don't trust your fingers, lay a flat object such as a ruler, or I used my bubble level across the top.
Some people like slightly above flush. Myself I prefer flush. A lot of my cars were setup for tape which is about as flush as it gets so I stayed with it. I also prefer how easily the tires slide over a flush mount.
Postby waaytoomuchintothis » Tue Apr 26, 2016 9:01 pm
Cuts like that are called "fly cuts" by woodworkers. They are the easiest cuts to get perfect. Go for it, guys. Dave isn't glossing over anything- it really is easy. Look how clean his cuts are. I recommend a small router like the Bosche Pony. Super easy.
Postby dreinecke » Tue Apr 26, 2016 10:20 pm
Nice work there Dave! It is looking great!
Re: So-Cal Speedway upgrade, braid installed! With video!
Postby HomeRacingWorld » Wed Apr 27, 2016 12:38 pm
Great video!
Never gets old seeing those glide.
Postby chappy » Wed Apr 27, 2016 1:29 pm
Wow Dave, that is Soooooo Cooool. For Sooooo Caaaal
The video is great, and answered my question about sliding over the braid .
Beauty Job man.
And Thanks Harry, at least my thinking was on the right path for flush.
Good thread for those of us on the fence.
Postby glasshorsevh » Wed Apr 27, 2016 2:25 pm
Retro Rockabilly Slotcar songs and jalopy racing action?!! I'm rendered speechless....
glasshorsevh
Postby oldtymer » Wed Apr 27, 2016 3:59 pm
Shotgun....I like the new finish on the track.....after sanding did you use the Chalkboard paint again !
Fred
oldtymer
Cat Lovers Club Prez
Postby SlotCarCorner » Wed Apr 27, 2016 5:21 pm
Great thread Dave - lot's of useful info, pictures and a video!! Package heading your way in the a.m.. Mr. Reinecke, rest assured SCC is firmly committed to take away any and all excuses that will prevent Dave from finishing this project before your upcoming visit.
:lol:
SlotCarCorner
Postby Audi1 » Wed Apr 27, 2016 6:42 pm
The new track looks great, Dave. It looks like your jalopies definitely hook up better on the new track surface and the additional volts to the motors has to be a big plus. Cool video, too! :text-bravo:
Postby waaytoomuchintothis » Wed Apr 27, 2016 10:52 pm
Excellent work, Dave. Real craftsmanship. Inspiring.
Postby RichD » Thu Apr 28, 2016 8:30 am
Shoreline Model Raceways has converted a couple of tracks from tape to braid, going to braid is like turning up the voltage a little. It feels like you get an extra volt or so. Actually you do get an extra volt or so. Braid has less resistance per foot and when you get further from the place where the power taps are that has a noticeable effect, especially if you run cars with more powerful motors.
Postby dreinecke » Thu Apr 28, 2016 7:40 pm
That looks seriously great! I guess I'll have to come play now ;)
