Home Racing World • View topic - Mini becomes a Cheetah
Postby VTECFOUR » Sat Jan 09, 2016 6:52 pm
Luf passed a Strombecker Cheetah body to me. I didn't have a chassis ready to go so I thought about re-bodying one of my built cars. Turned out the adjustable wheelbase one from one of my Minis fit the bill.
With new body mounting posts and lengthening the adjustable wheelbase, it worked out fine.
Larger wheels/tires are more appropriate but I sort of like this low profile look.
Modeling work to come.
VTECFOUR
Re: Mini becomes a Cheetah
Postby dreinecke » Sat Jan 09, 2016 11:32 pm
Good looking car - the chassis should make that thing fly.
Postby vonsirius » Sun Jan 10, 2016 12:33 am
Cool!
Cheetahs always win :D
vonsirius
Postby Retro Racer 44 » Sun Jan 10, 2016 12:44 am
Looks good Dan, now you will need the side pipes again. If you do the flares again on this one, and make a mould, I'll want a copy. Please!
Retro Racer 44
Postby Czar » Sun Jan 10, 2016 8:46 am
When I read the title I'll admit I was scared. But, nice job. I mean no offense, that hue of orange and the perspective in the last photo make it look a little bit like a Manta Ray.
Czar
Postby acmost » Sun Jan 10, 2016 9:03 am
All hail the Cheetah...love that chassis.
acmost
Postby VTECFOUR » Sun Jan 10, 2016 4:51 pm
Made some side pipes from brass tube, 1/8" into 5/32", and solder at the other end.
Filled the void nicely.
Waiting for the windscreen plaster plugs to dry and then vacu-forming at Luf's tomorrow.
Just doing this one-off for now.
VTECFOUR
Postby JT Previa » Mon Jan 11, 2016 10:48 pm
Dan, I just need to say:
Friends don't let friends slam Cheetahs!
The gods of slotting history will not be pleased. Reprimands will follow...
Next, you'll be making a targa roof version, or even a rat rod version...or maybe even a targa roof / rat rod version with a serape blanket on the seat! :whistle: Oh, wait...
But, if you are intent on making an orange, holy grail destroying model (with admittedly, nice craftsmanship), you could call it a Thingie, or add some hydraulics to those coaxial post body mounts you typically use!
JT
JT Previa
Postby VTECFOUR » Tue Jan 12, 2016 1:13 pm
@ JT - Should have known the Cheetah was sacred to one of the NERF boys. Oh well, wait till you see what more mods I have in mind!
@ Shotgun - to vacuform the windscreens, I made a male plaster plug by:
- pressing the original screens into Play Doh modeling material to form an impression and carefully removing them.
- mixing Plaster of Paris and pouring into the impression.
- waiting 24 hours for it to dry and voila.
- clean surface imperfections with a fine sanding pad.
The vacu forming was the easy part when you've got access to this beauty of a machine.
Thanks Luf.
Lessons learned.
- Let the plaster dry completely before handling.
- Wet the Play Doh mold before pouring in the plaster.
- Don't try to save the Play Doh in a baggy. Just let it dry out on the work table.
- Make the plug about a 1/4" thick. Not too thin so the mold will crack when the PETG is sucked down and not too thick so it's hard to remove.
My first try on the Toyota S800's windscreens turned out better. I actually left the windscreens in the mold and poured plaster into that. Plug came out cleaner and subsequently the windscreen pops.
Hope this helps.
VTECFOUR
Postby JT Previa » Tue Jan 12, 2016 1:21 pm
JT Previa
Postby acmost » Tue Jan 12, 2016 2:11 pm
acmost
Postby VTECFOUR » Thu Jan 14, 2016 1:08 am
Some modelling progress.
- removed A pillars and sanded body
- made headlight covers from .040 styrene
- fabricated interior tray from .015 styrene painted black with half driver figure
- trimmed vacu form windscreens
- salvaged intake manifold/carb detail from Monogram McLaren 8A
Primer's next.
VTECFOUR
Postby VTECFOUR » Thu Jan 14, 2016 8:32 pm
Tamiya Fine grey primer's on.
Thinking of a silver finish coat and side pipes in white.
Coming along well.
VTECFOUR
Postby Cincyslots » Thu Jan 14, 2016 9:07 pm
That looks great!
Bruce
Cincyslots
Postby JT Previa » Sat Jan 16, 2016 11:07 pm
Cheetah Ray!
(as noted by Czar: lots of Manta Ray in that car.) Similar to a Chip Foose retro renovation too.
Are you/can you move those front wheels back a bit to better inhabit the wheelwells?
JT
JT Previa
