by Foamy » Tue Sep 16, 2014 3:34 pm
NO WATER BEAK IN FOR ROAD RACE MOTORS!!! The brushes changed a couple years back and they die quickly. If you really must for some reason, then 5 seconds MAX at 4-ish volts. The OEM brushes aren't that great, but the Gold Dust brushes run swell. You need to shorten them about .040" or so to fit. Koford sells the Bigfoot 2 brush that is already radiused to the length you need for the mini motor. On really high power, the Koford brush runs a bit cooler than the Gold Dust, but the Gold Dust are faster.
