The new SoCal Speedway-Update
Got Wood?
Your ROUTED TRACK Home!
Re: Shotgun Speedway re-born
Postby TuscoTodd » Thu Sep 04, 2014 8:45 pm
Boy Dave - you aren't wasting any time!
Looking forward to your continued updates!
Postby Ember » Thu Sep 04, 2014 10:45 pm
So... When do we see track plan drawings? :lol:
Postby Ember » Fri Sep 05, 2014 12:07 am
Only single lane?
Postby Florida_Slotter » Fri Sep 05, 2014 3:27 am
So, where's the construction photos?
Postby Vintage 1/24 » Fri Sep 05, 2014 7:25 am
This sounds very good!
Make it as wide as you can allow - I personally believe 2:1 is the 'Golden Ratio' for the classic short track oval (as space allows). The wider the track, the larger the diameter of the turns - the better for driving, modulating, and controlling the cars - which makes competitive races more fun. Low banking also sounds great - should replicate the real short-track ovals perfectly.
Also, building as large as you are (16 feet), you could easily accommodate four lanes - which you might consider - if the track is built as you describe, the track itself will compel racers to show up!
I will be watching this space - keep the build pics coming!
Vintage 1/24
Mr. NY Modified
Postby btaylor » Fri Sep 05, 2014 8:29 am
Thats about the same marshaling area i have Dave, It works great,and i have drivers stations spaced all around the track.
evens on one side, odds on the other. that way there is always someone near a corner,even when there are just a couple of racers.
Postby waaytoomuchintothis » Fri Sep 05, 2014 9:55 am
Did you hear they found Jimmy Hoffa? He was covered in little bitty slot car body parts. And socks. And carburetor screws.
Postby studioRS » Fri Sep 05, 2014 12:23 pm
How did I miss this! WTH, this is going to be a nice redesigned track, can you say drift? Well, Dave I had the honor of you racing the flying eggplant Porsche RSR on the old track before it was kaput. ;)
Cheers, Thompson
studioRS
Postby waaytoomuchintothis » Fri Sep 05, 2014 1:46 pm
You betcha, pal. On the way tomorrow, I hope. Monday for certain.
Postby waaytoomuchintothis » Fri Sep 05, 2014 2:54 pm
Is that the loud noisy A/C unit that died? Home Depot has some excellent 120v units. I have two in a steel building 40x40x12 feet tall, and they handle the air temp and humidity when its 100 degrees and 70% humidity outside. I think they were about $150, end of the summer sale, maybe 5 years ago.
Postby btaylor » Fri Sep 05, 2014 3:16 pm
Damn it Boy!!!! you are going to town on this project! looks great so far.
sometimes a clean slate makes the build that much more fun, bare space, blank palette!=BIG OVAL!
Postby SRQSloter » Sat Sep 06, 2014 3:00 pm
Holy Buckets!!! Look at all them NASCAR cars. :lol: :handgestures-thumbup:
SRQSloter
Postby SRQSloter » Sat Sep 06, 2014 3:21 pm
Like that Gullwing.
SRQSloter
Postby HomeRacingWorld » Sat Sep 06, 2014 4:15 pm
Looks pretty good to me. See you when you get back :)
Postby TuscoTodd » Sat Sep 06, 2014 4:51 pm
Now that was a slick idea to re-purpose part of the old track into shelves! I like it Dave! :)
Return to The Lumber Yard
