Home Racing World • View topic - Cherokee point
Cherokee point
Plastic Or Wood
All Things Track Building!
Cherokee point
Postby btaylor » Tue Aug 12, 2014 2:37 pm
Starting to see some progress on my new road course, Dubbed, "Cherokee Point" after the rich Native American history around these parts.
The frame work design is copied from David's track at RMS, the PDR. The track mounting ribbon is made from 1/2" osb allowing me to twist the surface for camber and elevation. The plastic test track is 1959-66 Strombecker, to be removed when its time to route some wood and screw down to the OSB .Track measures 15' long,L-shaped with 9' ,55 ft running length at this time.
Re: Cherokee point
Postby btaylor » Tue Aug 12, 2014 2:48 pm
Thanks Dave! I will probably fill in the holes between the surface with screen wire and maybe mud it,but no scenery till I finalize the design.
Re: Cherokee point
Postby HomeRacingWorld » Tue Aug 12, 2014 2:51 pm
Oh yeah, you are doing great. Way to get after it.
Re: Cherokee point
Postby Ember » Tue Aug 12, 2014 3:32 pm
I see a track growing. Exciting times.
Re: Cherokee point
Postby TuscoTodd » Tue Aug 12, 2014 6:32 pm
That looks pretty cool! Thumbs up! :D
Re: Cherokee point
Postby btaylor » Wed Aug 13, 2014 8:07 am
Re: Cherokee point
Postby dreinecke » Wed Aug 13, 2014 9:45 am
Bob - I like the design! If it is only a test, do you really need to tack it down? I'd only put a few dabs of hot glue under a few pieces if you aren't t keeping it long before routing.
Re: Cherokee point
Postby btaylor » Wed Aug 13, 2014 10:45 am
Thanks David! I am pretty happy with the design so far, running on it will tell! I am only tacking down the track in the corners as I have given all of them a little banking. Not sure how long it will be before it gets routed? I want to give the design a good testing before I finalize the more permanent MDF. Could be a few months,and since I am taping the plastic it does not need to be able to move much.
Re: Cherokee point
Postby btaylor » Thu Aug 14, 2014 5:48 pm
Track painted and one lane taped!, whew! hand taping is a job!
Got to make a few laps tonight, Not sure about this design tho?
Re: Cherokee point
Postby LAMing » Thu Aug 14, 2014 7:35 pm
LAMing
Re: Cherokee point
Postby dreinecke » Thu Aug 14, 2014 10:18 pm
Bob - it looks great so far!
Re: Cherokee point
Postby btaylor » Fri Aug 15, 2014 4:01 am
Cherokee, eh? I live near the Choctaw Nation... and just a stones throw north of me is the Cherokee Nation. You from Oklahoma? I'm in eastern OK.
(Nice track, btw!)[/quote]
I am in Georgia, the other end of the "Trail of Tears", I live in an area that once was one of the largest Creek indian settlements in middle GA..This area was mostly populated by Cherokee and Creek. I have a lot of family in Ok though!, Mostly in Muskogee.
Re: Cherokee point
Postby btaylor » Wed Aug 20, 2014 5:36 pm
Gaining some ground after a major setback, all the old track had to be pulled because my latex paint was bad and would not dry. Thankfully I still had about 75 ft left,so no biggie. Only had one lane taped,so lost one roll there as well.
Anyway,got a lot done in the landscape so I wont lose cars off the table.
Re: Cherokee point
Postby Ember » Wed Aug 20, 2014 6:33 pm
Shame about the setback. But glad to see you forging ahead regardless.
Re: Cherokee point
Postby ourwayband » Wed Aug 20, 2014 7:05 pm
