Home Racing World • View topic - Small drill press?
Small drill press?
Small drill press?
Postby ListerStormGT » Tue Aug 12, 2014 9:39 pm
Just curious if anyone has any recommendation for a small bench top drill press. I could really use one just don't have the space for something too big.
Re: Small drill press?
Postby reek455 » Tue Aug 12, 2014 9:49 pm
I have one for my Dremel that's pretty small. It can be purchased here:
http://www.walmart.com/ip/Dremel-Drill- ... c5b8dd5674
Rico
reek455
Postby waaytoomuchintothis » Tue Aug 12, 2014 9:59 pm
There were several still around the last time I looked. We were told they were going to dry up because there was no good way to make them cost less. Anyway, in no order for quality or price, Look for Sears, Grizzly, Woodtek, Micromark, Harbor Freight/Northern tool (same stuff), and Wen.
The Wen is interesting, priced at $80 or so, and very solidly built. I think you can get free shipping from this one-- http://www.amazon.com/WEN-4208-8-Inch-S ... rill+press
Postby Ember » Tue Aug 12, 2014 10:09 pm
I have the Dremel one and if you want any kind of accuracy, forget it
As with anything I'd say it depends on what you're looking to do. Currently looking at a Proxxon one myself for small work.
I've often drooled over the prices Micromark list and wish could get similar here.
Postby chappyman66 » Tue Aug 12, 2014 10:42 pm
It's all about your budget - although I agree that the Dremel version is really not viable.
I have the Harbor Freight version and while it's been relatively trouble-free it does have some slight wobble so it's not accurate enough to turn wheels. I suspect changing the bearings could fix it...I just haven't bothered because it's been good enough for what I do.
Grizzly (in general) is a step up in price and quality....and then you can go to good stuff like the vertical mills from Micromark for multi-function work.
Get the best tool you can afford, and you can keep it for years.
Postby HomeRacingWorld » Tue Aug 12, 2014 10:53 pm
C'mon old buddy, you have room
At Lowe's for $129.00
Taller but does not take up that much more footprint space.
Postby SRQSloter » Tue Aug 12, 2014 11:59 pm
Pretty good deal on these right now. http://www.micromark.com/microlux-bench ... ,8283.html
SRQSloter
Postby RazorJon » Wed Aug 13, 2014 12:19 am
Lee watch your yard sales and such
if you can get a older one it will probably be better than a new one
I bet you could get a used bench top for $50.00
Postby dr fabio » Wed Aug 13, 2014 1:14 am
dr fabio
Postby ListerStormGT » Wed Aug 13, 2014 8:33 am
Postby HomeRacingWorld » Wed Aug 13, 2014 8:45 am
That will work fine.
Need me to come out and help install? I'll bring the General for proper supervision.
Postby HomeRacingWorld » Wed Aug 13, 2014 8:51 am
Postby ddyke » Wed Aug 13, 2014 9:13 am
It is footprint you are usually worried about. I had a dremel but when the the dremel burned out the new one had a different shape and the thing was useless. I have my mill and a huge drill press. The footprint for the huge one is no bigger than the mill. I would get one like Harry suggested or a little bigger. Just take a tape measure and compare the difference in the footprint vs. the space you can set aside vs. the money you have. Tools have many uses besides slot cars.
ddyke
Postby dreinecke » Wed Aug 13, 2014 9:30 am
I have the Dremel workstation and it is fine for my needs. My ryobi drill press just wasn't accurate enough and I recently sold it.
Postby Cobra Freak » Wed Aug 13, 2014 11:30 am
I have this one and would recommend it:
http://www.micromark.com/microlux-3-spe ... ,7797.html
I find the Dremel used in their workstation too fast, which can be very hard on bits.
Cobra Freak
Return to SlotCar ToolTime
