Home Racing World • View topic - My home slot racing center, work in progress
SHOW YOUR SLOT CAR TRACK!
Re: My home slot racing center, work in progress
Postby demether » Mon Aug 11, 2014 4:17 pm
thanks!
Tommorow I have to buy these wood borders for the straight lines of the track. I hope I'll find something cheap and eficient in bigger stores than the local one.
Then, I'll be able to start track building, I can't wait !
demether
Postby TuscoTodd » Mon Aug 11, 2014 5:08 pm
WOW! That blue really stands out nicely! Lookin' sharp!
Postby demether » Tue Aug 12, 2014 9:09 am
demether
Postby btaylor » Tue Aug 12, 2014 9:36 am
Try using some cut down metal coat hangers for your fence poles,they work great and are cheap. and not to far out of scale to my eye. I Drilled through the apron wall from the top to help support the fence.
Postby demether » Tue Aug 12, 2014 10:37 am
Great idea, thanks. I was thinking using some grid I found (used to dry clothes), but your idea is better. I have to see if I can find this cheap in my aera (a lot of things are insanely expensive here).
For the installation, I was thinking the same !
demether
Postby dge467 » Tue Aug 12, 2014 8:05 pm
Looking really good! Nice craftsmanship!
Postby demether » Wed Aug 13, 2014 3:28 pm
demether
Postby demether » Thu Aug 14, 2014 11:44 am
demether
Postby dreinecke » Thu Aug 14, 2014 12:09 pm
Seriously great work so far! Those borders and fences are going to be excellent!
Postby TuscoTodd » Fri Aug 15, 2014 5:06 am
That is going to look awesome!
Love the updates! :D
Postby demether » Fri Aug 15, 2014 9:27 am
Thanks !
I started painting the fences, they are drying in the attic. I'll make some pics tonight or tommorow morning.
Basically, I used some primer spray paint, and tommorow I'll make an extra coat with a foam roll, to give some texture to the walls.
I hope to finish them and maybe start installing the track before the end of the week.
demether
Postby demether » Fri Aug 15, 2014 12:19 pm
demether
Postby btaylor » Fri Aug 15, 2014 12:33 pm
I used these after i painted my retaining walls,ended up looking pretty good.The add says HO but they are perfect size for the artin walls.
http://www.ebay.com/itm/Slotcar-Racing- ... 1c4287e08b
Postby demether » Fri Aug 15, 2014 2:24 pm
I'm still wondering if I'll use some banners on the artin walls, or keep them blank. If I choose to add them, I'll make them myself (I'm a former graphist) with label paper I have. ;)
demether
Postby demether » Sat Aug 16, 2014 11:41 am
demether
Return to Reader's Roads
