Is it normal for urethane tires to coat the inside of your slot car body with loads of fine powder?
I just built a stocker with the PG supewide tires,and the tires are seemingly shredding.They are not touching anything but the track,no body or chassis rub. I'm using an M/T-5 motor,and its slides out thru the corners pretty good.
Just curious,as I have not used these before.
