Home Racing World • View topic - Slot Car Corner '73 IROC Proxy - Builds & Usual Chatter
Re: Slot Car Corner '73 IROC Proxy - Builds & Usual Chatter
Postby SRQSloter » Thu May 22, 2014 5:15 pm
Rob, Does the water need to be pretty hot? Hotter the better.
SRQSloter
Postby waaytoomuchintothis » Thu May 22, 2014 5:23 pm
I didn't have any places that required a big dip into a crevice, so I was just above lukewarm and it did fine. But my body doesn't have a lot of sharp lines on it. Others, especially if they enhanced the edge lines of doors by scribing the resin, may be well advised to use hot. There were only a couple of the decals that had no stickem at all, and they were no trouble to glue. Being wet already, they smoothed out the glue instantly.
Postby studioRS » Thu May 22, 2014 8:27 pm
studioRS
Postby studioRS » Thu May 22, 2014 8:37 pm
studioRS
Postby dreinecke » Thu May 22, 2014 9:19 pm
Thompson that thing looks simply brutal!!!
Postby waaytoomuchintothis » Thu May 22, 2014 9:26 pm
I don't understand why you posted all those shots of the front that already fits fine?
So you Dremeled the rear of your body to fit the decal? I suppose I may be able to go back and do that and touch up the paint again, but it would have been good to know that back when you first found the problem. A lot has been done since then. So you ground off the taillight and then carved the lights back in place further over?
Postby SRQSloter » Fri May 23, 2014 12:19 am
I thought that the raised square part was to be the taillights. :doh: Guess the goodyear will be between there now.
SRQSloter
Postby studioRS » Fri May 23, 2014 4:51 am
studioRS
Postby studioRS » Fri May 23, 2014 5:03 am
studioRS
Postby waaytoomuchintothis » Fri May 23, 2014 9:14 am
Postby SRQSloter » Fri May 23, 2014 12:11 pm
My little squares will be painted red and decals reversed unless you want to hook me up with a couple decals to fit between them Thompson. :)
:handgestures-thumbup:
SRQSloter
Postby studioRS » Fri May 23, 2014 12:45 pm
studioRS
Postby SRQSloter » Fri May 23, 2014 12:49 pm
Sounds good Thompson. Get that to ya in a bit. I'll give ya length and width in mms. :)
SRQSloter
Postby waaytoomuchintothis » Fri May 23, 2014 8:36 pm
I carved up the back end today, and it came out fine. I'll finish up the decals tomorrow and get the Future on this thing. I glued down three more lifting decals today, too. I think I'll airbrush the Future on to make sure I don't mess up decals with my usual brush.
Postby waaytoomuchintothis » Fri May 23, 2014 10:20 pm
Damn. I forgot all about that. I'll try it on a test piece with my trusty eyepatch. ARG!
