by bill from nh » Mon May 12, 2014 8:42 am
David, the Parma Flexi 3 is an anglewinder chassis rather than an inline like most of the others shown. As such, it has a motor bracket just ahead of left rear upright. The stock motor bracket fits a 16D size motor but it can be ground to fit others or the motor can simply be soldered in. The Parma square bushings are rock-solid in their Flexi 2, 3, 4, & 5 chassis made for them. Parma sells square bushings to fit 1/8" or 3/32" axles, with your choice of either centered or offset axle holes. In addition to the different weight steel pans for the Flexi 3, Parma also sold an aluminum pan to fit. But the thing would bend when you looked at it cross-eyed.
