Home Racing World • View topic - The Abecedarian Proxy (Beginner's Carrera Proxy)
Re: Beginner's Carrera Proxy (for Slot Car veterans too!)
Postby HomeRacingWorld » Thu May 01, 2014 7:43 am
Postby TuscoTodd » Thu May 01, 2014 7:47 am
Ember / Czar / Harry -
Appreciate the insight and the link to just what I need!
:banana-dance:
Can't ask for better help than that! :D
Postby Austin » Thu May 01, 2014 9:43 am
Austin
Postby Burrell » Thu May 01, 2014 12:01 pm
Burrell
Postby TuscoTodd » Sat May 03, 2014 10:40 am
Work has started on my Ferrari 458 GT2 and a couple questions have come to mind in regard to car prep and rules that I wanted to ask on the forum as I think they may be of interest to all:
1) Will all of the host tracks accommodate the stock Carrera guide blade depth? (ie - the one that came on my 458 GT2 would bottom out in Scalextric Classic / SCX / Eldon track). If the blades need to be trimmed - what is the max slot depth?
(for reference - the track I am potentially volunteering allows for full depth guides)
2) I didn't see it in the "allowed" tuning items, so I wanted to ask if it would be "ok" to use spacers/washers/etc to limit side to side axle play?
3) Is there a minimum ground clearance requirement? And if so - is it acceptable to "remove" material from the bottom of the chassis?
The reason I ask this is multi-fold... And while I'm not sure if this is something specific to the Ferrari 458 GT2 or all the GT class cars - but thought I would bring it up here as I think others may run into the same issue I am noticing and don't want to see anyone's car run into issues with dragging/bottoming/etc.
I was going to shoot for the kind of normal .050" min clearance type number... But being new to Carrera cars, I thought I should check to see what it was stock BEFORE doing anything like truing wheels, the stock tires, etc. This is where I was a bit surprised! Using feeler gauges and my set-up block, I found the raised (or lowered depending on your perspective) portion of the chassis for the rear most magnet pocket currently allows for just .056" clearance on my car before doing any truing!
Here is a shot of the rear magnet pocket area I am referring to:
or for an overall shot of the bottom of the chassis - here is a shot from the Homeracingworld review of this model here: http://www.homeracingworld.com/c458bottomchassis1.jpg
In checking the balance of the chassis clearance is .100" or more. While I am going with Paul Gage tires on my entry, which should start slight larger than the factory tires to allow truing without taking the magnet pocket below .050" ground clearance - it is conceivable those wanting to use the factory rubber could end up with less than .050" causing a potential for dragging, etc which will definitely have a negative effect on how their cars would perform in the proxy - which would be unfortunate. (if the offending area can be trimmed / then reinforced if need be - then it should be a non-issue)
4) Another clarification question that goes hand in hand with the clearance question - I am assuming that any weight that is added is to be "inside" the car/chassis. (ie - no lead, brass, etc stuck/attached to the bottom of the chassis)
5) And finally... Do the axles (the front axle in particular on my car) have to stay in their original installed location or is it acceptable as part of the "tuning" process / gluing the bushings in - to shim them up slightly to get more guide engagement / pick-up contact? (note: on my car even with removing the front tires off the wheels the car does not fully on the guide) Here is a shot of what I am referring to:
(For reference, just leaving the braid flat, there is an easy .070" between the braid and the block with everything as delivered)
Shimming the axle would be relatively simple for all to do - but if it isn't to be allowed, I completely understand and will just true the tires as small as possible to help the issue.
I "think" that is all the questions I have for now. Look forward to the "clarifications"! :D
Postby Burrell » Wed May 07, 2014 7:49 am
Burrell
Postby TuscoTodd » Wed May 07, 2014 11:16 am
Burrell -
Thank you for the follow up - I appreciate it!
Look forward to the getting the "rulings" on the above. :)
Postby Ember » Fri May 09, 2014 5:51 pm
Guys, I have a question regarding guides. May they be trimmed? While Carrera hw ship an optional smaller guide with their cars aimed at use on Scalex track, these guides are still too big and deep for use on some. My own track is Scalex Sport based with some narrow radius turns in the mix. Even the smaller Carrera does not run well.
Postby Burrell » Fri May 09, 2014 6:21 pm
Burrell
Postby TuscoTodd » Fri May 09, 2014 6:28 pm
Ember -
I hadn't thought about the radius of the curves - that is also a very good point! I had only noticed that the overall height (depth) of the blade would most likely be too much for Eldon/SCX/Scalextric Classis/etc track. But similar to trimming the height (depth) I wouldn't see any reason that they couldn't be trimmed for in length as well?
We would just need need those that are planning to "host" to advise what would be appropriate for their particular track, and then utilize a combination of whatever ends up being the shallowest and shortest dimension. (while not trimming any more than necessary)
I know that on the track I am offering to host at, the stock large guide is acceptable on all accounts - but this track is a large commercial, routed, wood track with relatively big sweeping turns - I am sure that some of the other tracks will require trimming
Hopefully Czar will be back available to post this weekend and can give some guidance on both your and my questions as I am itching to get back to work on mine as I usually only have one day a week where I can get to the track and I'm curious to see how well I can get this Ferrari to handle. :D
Postby TuscoTodd » Fri May 09, 2014 6:29 pm
Burrell -
For the track here - no trimming required of the large supplied guide flag is necessary.
Postby Ember » Fri May 09, 2014 6:45 pm
It's possible that I am the only one that will have problems with it. But, it's kind of difficult for me to tune a car I can't really succesfully test. It will run, just not comfortably. It is on of the reasons I don't own much in the way of Carrera. The B-Nova adapter has solved that problem, but I've not been in a position to buy more cars to try it out on.
Postby TuscoTodd » Sat May 10, 2014 2:49 pm
WhooHoo! My Paul Gage tires showed up today! :D
More progress to be had shortly!
Postby VenturaAlfa » Mon May 12, 2014 10:58 am
No Trimming required for my track. There are some tight turns but the only car to ever have a problem was the Carrera Charger and superbird that had that ridiculous guide that was attached to the magnet in the middle of the chassis. They got around the track but it wasn't pretty.
I am still looking for suggestions for a GT car. Do the Capri's qualify? how about the Dekon Monza?
This should be fun.
Ventura Alfa
VenturaAlfa
Postby reek455 » Tue May 13, 2014 3:51 pm
What is the timeline here? I'm interested in throwing my hat in the ring. I will have to get a car as I don't have any Carrera Modern GT's. I have my eye on one though...
Rico
reek455
