Home Racing World • View topic - Bobbyraz's red lane
Bobbyraz's red lane
Got Wood?
Your ROUTED TRACK Home!
Bobbyraz's red lane
Postby bobbyraz49 » Fri May 02, 2014 7:12 pm
bobbyraz49
Re: Bobbyraz's red lane
Postby chappyman66 » Fri May 02, 2014 7:41 pm
Bobby,
What tires are on the car? For silicones, the track must be very clean. Rubber tires will slide all over until you run a lot of laps, and the groove will "rubber in" and you will get much better traction.
It's not unusual to have a pretty slippery first few laps....the important thing is that the track is alive!
Postby chappy » Fri May 02, 2014 8:20 pm
Bobby just like chappyman says.
New track , lots of laps to break it in.
I dont use silicones so I cant comment there.
Rubber or urethane, same as new track, lots of laps.
If you have some grip but not on corners it could be balance, but I agree with chappyman.
Postby bobbyraz49 » Sat May 03, 2014 7:06 am
I ran silicone's on my 1st test lap with a Scaley and it got me VERY frustrated. VERY !!!
So I put on a Carrera car with stock tires and was just as bad. What are stock tires on Scaleys and Carrera mase of ?
The thing about the Carrera is that the guide pin is so long that the car gets stuck in spots while I had no issues with the Scaley.
I have NO grip !!! The tires were spinning even while on a long straight section.
The enjoyment I had making my own track was lost when I used the battery on the copper and the cars swung way out on every turn .
Thanks folks...any and all comment/suggestions are welcomed and encouraged.
bobbyraz49
Postby Florida_Slotter » Sat May 03, 2014 7:22 am
Bobby,
Right now you have a "green track" or one that has no rubber on it.
We had the same issue with our track, but lots of running of laps have created a super surface now.
We run Yellow Dogs or Paul Gage urethane tires only on our track.
Worked for us.
Postby bobbyraz49 » Sat May 03, 2014 7:25 am
bobbyraz49
Postby Ember » Sat May 03, 2014 7:27 am
I think the stock tyres are synthetic rubber.
My surface is completely different to yours, but I found Paul Gage's XPG urethane some of the best around. It does take some laps to build up good grip.
Postby 2FER SLOTS » Sat May 03, 2014 8:18 am
Going from plastic and magnets to fresh wood and no magnets would be a steep learning curve :? ....but a really fun one :dance:
2FER SLOTS
Postby chappyman66 » Sat May 03, 2014 8:27 am
Bobby, I am not sure you need all new tires. Mostly you just needs lots of time running laps.
Get the other lane braided and your driver's stations wired and then go to town. You will notice the surface getting better as you race.
Postby Florida_Slotter » Sat May 03, 2014 9:20 am
Bobby,
I never said you need new tires. I was stating what we run.
However you will need to take many laps to wear the surface in. When you start to see permanent rubber tracks you will be getting close.
It's really a fun job.
Postby bobbyraz49 » Sat May 03, 2014 1:19 pm
Thanks all for the suggestions. MUCH appreciated and welcomed.
I have the copper tape on the blue lane and it tested well.
Yes....plastic to wood is like night and day. I ran laps on ModlerBob's track in Florida which is what made me want to give this a try.
Heading down south ( Florida) for a week and upon my return....the wiring process will commence !!
Hey Florida Slotter....what part of Florida do you reside ? Do you know ModlerBob ?
bobbyraz49
Postby Florida_Slotter » Sat May 03, 2014 10:14 pm
Buffalo Bob,
Well my other name is Marty. We met on your first visit to ModlerBobs place.
I will be there on the 12th for your visit.
Postby bobbyraz49 » Sun May 04, 2014 6:14 am
bobbyraz49
Return to The Lumber Yard
