Officially the shell is a Mark II Sprite by FPF Models. But as it shared so much with the MG Midget it will always be a Spridget to me.
Make it up as you go along chassis in progress.
Mostly finished. Still missing a rear axle bushing here which fell out on the floor somewhere.
Test fitting motor etc.
Got to do some heavy duty filing on the internal rails to try to drop the motor a little. Things must've rolled while I was soldering.
Test fitting shell.
Some grinding to do on the tyres still. I've had to take a lot of meat out of the sides of the shell.
