Slotwings 512 Tuning - Wheel Inserts
Postby HomeRacingWorld » Sun Jan 19, 2014 1:50 pm
I am using the CB Design 15x10 wheel to rebuild this car. Wanted to use the original wheels for inserts, but it takes a little extra time so thought I would share the process.
The BBS plate is easy enough to pop out. I used a tweezers.
Inside the wheel you see the lock nut detail. I was wondering how to keep this detail on the conversion and the answer was not to try. Instead I will use the ends of the axle to simulate it.
When you cut off the wheel at the depth you need, the center nut detail is left behind.
This is what you end up with.
Make sure to make a small notch on the insert to clear the screw/wrench access.
I cut the axles at a longer length so the axle itself would simulate the nut.
Not bad. Looks almost identical, especially when you are a foot away or at speed.
Re: Slotwings 512 Tuning - Wheel Inserts
Postby HRWJim » Sun Jan 19, 2014 3:13 pm
Very nice...that's why you run this place. Jim
Postby ListerStormGT » Sun Jan 19, 2014 3:49 pm
Great idea Harry, yep this is why you are the Boss around here!
Postby FootScoot » Sun Jan 19, 2014 5:31 pm
Sometimes those wheels can be a pain to make insert out of. I know I spent the better part of 2 hours making some for my VW Beetle project. Those look real good Harry, real good. :)
Postby reek455 » Mon Jan 20, 2014 11:11 am
Nice work sir, those look great. I suppose one could even file/grind the end of the axle into a hexagon to complete the effect.
Rico
reek455
Return to The Slot Car Garage
