Home Racing World • View topic - CHARGER/STREET STOCK VIDEO
Postby Beach Oval » Sun Jan 12, 2014 3:43 pm
Beach Oval
Re: CHARGER/STREET STOCK VIDEO
Postby TuscoTodd » Sun Jan 12, 2014 5:01 pm
Seems to be a lot of "Rubbin' is Racin'" in this class with how loose those bad boys seem to be (you can see them kicking out pretty notable even in the arch on the back stretch!) - Looks like a fun class to run though! :D
Thanks for sharing the vid!
Postby Halfj-7 » Mon Jan 13, 2014 10:26 am
That looks like fun right there. Whats the class rules/specs?
Halfj-7
Postby Beach Oval » Mon Jan 13, 2014 4:55 pm
Thanks Tusco and Shotgun.
It's a good running Division we have been running for years, and this is @ 10 to 10.25 VOLTS we are running at.
Don't know Patrick Bib, same driven" style???? :o
Halfj, This is the Rule Sheet for my Track
STREET STOCK
Chassis - WOMP 1 cut, MUST RETAIN WHOLE CHASSIS, No cutting out of Center Section.MUST RETAIN OUTSIDE PERIMETER.
May drill Hole up to 3/8” for Motor Cooling.
Chassis my be Re-Inforced, MOTOR BRACKET and AXLE SUPPORTS.
No bending chassis front guide flag axle area. Slight Bend Of Rear Axle OK.
No HINGING of Chassis
No drilling of front and rear axle area and no altering oil lite holes in any shape or form. No hogging
No rear ball bearing oil lites
MOTOR Sealed S16D or SEALED PARMA 502 or ProSlotFX PS-2003 S16D MOTOR ALLOWED, NO WASP OR 12. MUST RETAIN STOCK SPRINGS AND BRUSHES NO TWEAKING SPRINGS
NO SHUNTING OR BALL BEARINGS IN CAN OR END BELL ALLOWED.
ANY GEAR RATIO ALLOWED
BODY WE WANT THESE CARS TO LOOK LIKE YOUR SATURDAY NIGHT STREET STOCKS
ANY 60’S AND UP MID SIZE CAR AND PONY CARS ALLOWED.
NO CUTTING OR TRIMMING OF ROCKER PANELS
NO NASCAR, ASA OR IMSA BODIES ALLOWED.
CARS MUST HAVE BUMPERS, BRASS OR STEEL BUMPERS ARE OPTIONAL.
MUST HAVE 3 NUMBERS, WINDSHIELD, DRIVER AND INTERIOR
Tires - front and rear tires, Minimum Height of .940
May Nail Polish Fronts. Any rim size allowed
Front Axel may have Free Wheel.
Must Fit in Tech Tool, 3.25” Width
No off-set of wheels, must be centered and fit inside tech tool.
Must have SAME SPACERS on BOTH SIDES
AXLES MUST USE SOLID 1/8” AXLE, DRILL BLANKS OK TO USE and may be Shortened
RIDE HEIGHT MUST CLEAR 1/16” BASIC PARMA TECH TOOL.
Beach Oval
