Home Racing World • View topic - Long Creek Raceway
Long Creek Raceway
SHOW YOUR SLOT CAR TRACK!
Re: Long Creek Raceway
Postby dreinecke » Sat Aug 10, 2013 4:56 pm
Track looks like it is coming back together! Nice work! How's the track flow now?
Postby Halfj-7 » Tue Dec 17, 2013 9:28 pm
Long time since an update. Decided to remodel other half of garage and make a nice workspace. Got most of foam work done with plaster on a third of it. Definitely needs rubbered in.
As far as flow goes I'm getting the rhythm down. One section needs a tweak though. Pics to follow...
Halfj-7
Postby dreinecke » Tue Dec 17, 2013 9:55 pm
...ok...you've had a few minutes! Stop running laps and give us pictures!
Can't wait to see it.
Postby Halfj-7 » Sun Feb 09, 2014 7:05 pm
Well the track is no more. Took it down to make way for a "roval" that I can run 1/24 and 1/32 cars. I did a sloppy job on some of the newer routing and it just didn't turn out the way I wanted. Oh well I enjoy building tracks almost as much as running them.
Halfj-7
Postby Fast Co. » Mon Feb 10, 2014 4:17 pm
Wow, you change tracks faster than master Luf! :lol: I was getting into the build of both of those tracks. I'm sure the next one will be amazing too...
Fast Co.
Postby bobbyraz49 » Thu Mar 27, 2014 6:41 am
So the copper tape bends easily when placing it on the turns >>> TY
bobbyraz49
Postby Halfj-7 » Fri Mar 28, 2014 3:57 pm
I do just like bibbster does. I also "burnish" the tape in with a 4" hard rubber roller that is commonly used for making laminate countertops and cabinets. I've used a bic lighter body before too. I still get a few places that want to pop up but my tracks see a lot of temperature swings in the garage.
Halfj-7
Postby Halfj-7 » Fri Mar 28, 2014 4:01 pm
The new track will will becoming along soon. I have to finish some remodeling projects around here and I'm having so much fun with the oval! And just picked up a new hakko soldier iron with a pile of brass.... at least I have the sketch done and some lumber leftovers from work
Halfj-7
Postby indybob007 » Fri Dec 12, 2014 8:59 am
Bump' Have you ever started the oval.
indybob007
Postby bobbyraz49 » Fri Dec 12, 2014 10:34 am
bobbyraz49
Return to Reader's Roads
