Home Racing World • View topic - HRW Autograss Mini Proxy
Re: HRW Autograss Mini Proxy
Postby hoganracing » Thu Nov 21, 2013 9:53 pm
Thanks Dave.
I've already had lots of fun building this car. Time will tell if it holds up.
I'm looking forward to seeing pictures of them all together (especially since the background and lighting will be better than it is in my kitchen!)
Patrick
hoganracing
Frequent Flyer
Postby ListerStormGT » Fri Nov 22, 2013 5:25 pm
Finally finished mine up today...Dont know how well it will fare against the others but should be fun anyway. I will get it in the mail next week.
Postby HomeRacingWorld » Fri Nov 22, 2013 6:59 pm
Hopefully mine arrives tomorrow.
Looks good guys, great builds.
Oh Dave, careful with Hogan's machines. Best to cover any windows and make the kids wear safety helmets.
Postby hoganracing » Fri Nov 22, 2013 7:42 pm
hoganracing
Frequent Flyer
Postby waaytoomuchintothis » Fri Nov 22, 2013 8:46 pm
I had a big setback with one of mine. The design of that chassis makes it much faster going backwards as rear wheel drive, not what I had in mind.
I don't think mine will be competitive anyway, as I kept the wheels to scale limits. Some of these are a scale 20 inches tall or thereabouts. I stayed below 13 inches, the wheel size of a Caterham, which will just fit under a Mini, but is really crowded. The other car has scale 10 inch wheels. Just my preference for how they look.
Postby Wolseley Hornet » Sat Nov 23, 2013 10:39 am
Hogan and Lister, they look great.
Rob front wheel drive puts them way ahead , however they go.
David, I'm still racing to get the Hornet paint sorted out, and looking for guaranteed rapid mailing service. Stickers should be ready on Monday - and did the Hornet body shell get there yet? the last one only took 4 days. Maybe the USPS got a backlog after the government shut-down.
Just back from a couple of days away, and lurking on someone else's computer.
David.
Wolseley Hornet
Postby TuscoTodd » Sun Nov 24, 2013 3:36 pm
Well.... I DEFINITELY got behind on my build!
BUT! Today I am back to making progress!
The idea of using the Carrera Go wheels and tires, while "free" as I had them here - turned the project on it's head as I ran into issues trying to get a chassis built around press on wheels without having clip in bushings, while still being able to adjust gear lash (I didn't have any slot-it type gears around - only standard "non-capturing" type...
Soooo - chassis attempt #1 was finally scrapped today as I decided to go with set screw wheels...
Which led to the next issue - at this late hour - I didn't have time to order wheels / tires! So after a lunch break, it was back to the drawing board and the "spares" pile!
I have to say, what came out of it looks to have promise! It is going to allow me to use the Carrera Go! tires and wheels up front and tires with the wheels turned down on my dremel (have to get a mini lathe one of these days!) as inserts in the rear. The rear wheels are from some worn out JK8721P large hub tires that I removed around 3/16" of width from. All in all, I am pretty happy with how they turned out as it will still allow the car to have the "scale" size tires - but will fix my issue with not being able to come up with a good robust rear axle set up. :)
I snapped a progress shot and then a shot of what the finished product looks like...
Now I can get back to chassis design!
Enjoy!
:D
Postby Wolseley Hornet » Tue Nov 26, 2013 9:17 am
Defeated by the weather!
I had hoped to get a Hornet done in time for 1st December, but after a painting disaster, it's just too cold and humid here to get the paint to dry quickly - and even given time, it blooms.
So no second entry from me, I'm afraid. I'll post a picture of the Hornet when it's done.
David.
Wolseley Hornet
Postby TuscoTodd » Tue Nov 26, 2013 1:13 pm
David -
I can relate on the paint! I REALLY should have focused on the body back a bit ago. I ended up painting mine in the garage and then bringing it in the house... without using a primer coat... In order to try to have "some" color on it before shipping out. It may not be pretty - but my plan is to ship it out Friday! :)
Speaking of which - ShotgunDvae - if you can PM me the address to ship it to, I'd appreciate it!
Thanks!
Todd
PS - will hopefully be able to post chassis pics and preliminary body pics later tonight. :)
Postby waaytoomuchintothis » Tue Nov 26, 2013 3:51 pm
I'm out. Too much to do to get finished. As I say, though, mine wouldn't have been much fun with the scale sized wheels. I thought I might make up the difference with gearing, but it doesn't work. After the holidays, I'll get on it and finish them up. I'll post them then.
Postby HomeRacingWorld » Tue Nov 26, 2013 7:34 pm
Me too...what's a week?
Anyone object to allowing an extra week?
Postby waaytoomuchintothis » Tue Nov 26, 2013 8:03 pm
I'd like to endorse a week extension at least! Its up to the rest of the field. I said I would do it, and I had to give up. I am at the mercy of the group here.
Postby hoganracing » Tue Nov 26, 2013 8:16 pm
I have no objection to extending things a week. At least my car should be there in time!
Patrick
hoganracing
Frequent Flyer
Postby waaytoomuchintothis » Tue Nov 26, 2013 8:40 pm
That's two! Anyone object? Be brave, its okay.
Postby HomeRacingWorld » Tue Nov 26, 2013 8:43 pm
Done!
December 7th!
Now to ask Dave if it's really ok before I get banned.
