I recently tried stripping an old Ninco Ferrari 250TR, but found that the body wasn't painted after all, and merely was bare plastic with stickers applied. The stickers came off following a night spent in an alcohol bath and with a little scrubbing, but I can't seem to get the glue residue completely off of the body. I generally clean a body with regular Dial soap before painting, but even that isn't able to completely remove the glue. That leaves me thinking that Goo Gone would probably get the job done, but I'm concerned that it may adversely impact the body. I'd rather not melt or warp this particular body as it would be hard to replace.
:?: Has anyone successfully used Goo Gone on a slot car body, or failing that, are there other alternatives that I should first try?
Thanks!
