Home Racing World • View topic - Late Model Truck Build
Postby HomeRacingWorld » Sun Sep 15, 2013 3:34 pm
I am behind the times but at least getting things started.
The kit to start with.
The front clip is a separate piece so I had to strengthen it with some scrap styrene.
Roof chopped and time to start bondo :)
Re: Late Model Truck Build
Postby RazorJon » Sun Sep 15, 2013 4:42 pm
I just took my truck for a lap, better get building :naughty:
looks like a great start
Postby Austin » Sun Sep 15, 2013 5:51 pm
Wow Harry, You sure cut that truck up, Only wish I had the time to build the great looking chassis like you build
Austin
Postby HomeRacingWorld » Sun Sep 15, 2013 6:21 pm
Thanks Austin, but this chassis isn't going to be that pretty.
The chassis will be a "Frankenchassis" to go along with the spirit of these trucks.
Part Pro-Track, H&R, & scratch. :)
It is fun to cut things up. it is getting it back together that is the hard part!
Postby waaytoomuchintothis » Sun Sep 15, 2013 7:12 pm
I ran into an insurmountable problem with the track and I had to redesign the control panels. Maybe I can take a break from the track and build a truck... Especially one that is so much fun to chop up.
And I haven't forgotten that Coke car, either. The Nehi Grape machine is being gathered up for assembly. The custom made decals (incredible) were delivered Friday, and the purple paint is ready.
Postby HomeRacingWorld » Mon Sep 16, 2013 2:09 pm
Hey Rob, welcome to the madness.
Speaking of that...little update.
Still in mock up stages, but getting a good idea what I am after. I think :)
How to take a tweak out of a pick up bed. Use your Piston Cup trophy on top and use a blow dryer to cook the frame and presto!
I want an air filter. Hmmmm...these hubcaps look pretty cool.
Yes, that looks pretty good to me.
Just getting to the chassis. Front end will be cut off, but the rear bulkhead is good to go.
New chassis company that I think will work out just fine :)
Postby TsgtRet » Mon Sep 16, 2013 2:27 pm
Postby Derby City Speedway » Mon Sep 16, 2013 2:29 pm
looking good Harry, man I new I forgot something, I thought about the air filter, but forgot about it. O well, I`ll have to make a double stack on the next project to ,make up. :doh:
Hey that chassis looks like it will be close making the minimun weight requirements. May want to have a talk with IGOR..
Derby City Speedway
Derby City King
Postby Austin » Mon Sep 16, 2013 3:52 pm
Damn that's looking good, So good that I now cut the stupid roof off mine :whistle:
Austin
Postby sixtiesracer » Mon Sep 16, 2013 7:12 pm
"They were wrong,it's pronounced....Eye gore" :lol: :lol: .
sixtiesracer
The Rustinator
Postby RazorJon » Mon Sep 16, 2013 10:07 pm
you did what in your cup :o
Postby HomeRacingWorld » Tue Sep 17, 2013 7:56 pm
Here some progress on the Igor Chassis (ver 1.0)
Did some slicing on the pan and cut the side mounts to fit in the cab. Cut off the front bulkhead and created a slider type system from square brass tubing.
Works just fine. Just need to make the guide tongue now.
The front axle carrier is a double stack of the same size tubing. This made the chassis about as close to parallel as it gets for the Skunkworks.
Slide to adjust and it seems to fit ok.
A lot more to do, but making progress :)
Postby Derby City Speedway » Tue Sep 17, 2013 8:40 pm
Harry,
I think yours is looking closer to our beautiful model as anyones. Maybe it's because you've got your hood
Flatter that it resembles the model.
NASTY !! :twisted:
Derby City Speedway
Derby City King
Postby RazorJon » Tue Sep 17, 2013 8:49 pm
the hood is perfect, you nailed it :clap:
Postby HomeRacingWorld » Tue Sep 17, 2013 9:17 pm
Thanks guys, it's fun trying :)
