Home Racing World • View topic - Heller Austin Mini
Heller Austin Mini
Heller Austin Mini
Postby nerfbarz » Thu Jun 27, 2013 3:17 am
What HO running gear best fits the 1/43 Austin Mini? I picked up 4 brand new Scalextric straights at a thrift shop for $10 total and the rails look amenable to multiple scales. All I need is some R2s and four more straights to build my British-theme oval (I'm already designing 1/43 Reliant Robins. I'm torn between riding the pickup, or offsetting the motor pod to have a true tricycle front.)
Peter, I think you alluded to the HO-Mini lash-up in SCF but I can't find that post to which you referred.
Nerf
nerfbarz
Re: Heller Austin Mini
Postby LloydL » Thu Jun 27, 2013 8:14 am
LloydL
Postby LloydL » Thu Jun 27, 2013 8:21 am
Another one for Nerf:
regards, Lloyd
LloydL
Postby masmojo » Thu Jun 27, 2013 8:22 am
I believe Peter did a printed chassis for his last Mini, your best bet would be to find that on Shapeways and have one printed up!
viewtopic.php?f=6&t=2886
masmojo
Postby pfuetze » Fri Jun 28, 2013 12:18 am
The Mini chassis i did is available on shapeways.
Ranch-Design could do the wheels needed for the Mini, just let me know if the dimensions are needed. Tires came from Germany, from CarGo, i can give you his adress if you like.
i tried my luck with a Marchon H0 Jeep chassis at first, it needed to be lengthened by 3 mm, a difficult job, as the plastic of the chassis did not accept the glue in a good way.
A Tomy G+ or Tomy SRT chassis should fit the Mini body, but both need to be lengthened by app. 8mm to get the wheel base.
Those H0 chassis create real downforce on 1/43rd artin track!
somewhere in all these pictures, there should also be some of the first mini chassis i did. first in brass, then in styrene ...
http://s38.photobucket.com/albums/e106/pfuetze/cars
sorry, don´t know which H0 chassis fits nearly withoug altering it. Maybe one of those flat new F1 style chassis?
