Home Racing World • View topic - plastic vs. metal
plastic vs. metal
Re: plastic vs. metal
Postby DHansen » Wed Jun 12, 2013 6:07 pm
DHansen
Postby DAVE » Thu Jun 13, 2013 3:11 pm
Marty;
So Dennis finally came out with a coined nose piece. The car I have from him has a separate guide
tongue soldered on. I think I will invest in one. I also have a Can-Am chassis built by him. He and I
are both fans of Peter Bryant, and are the only ones who actually paint the Ti-22 bodies the way
they were actually painted.
DAVE
Postby slothead » Thu Jun 13, 2013 3:19 pm
In this link the Champion Thumper chassis looks like it's brass, but I've only seen it in steel. Is this just the lighting, or is there really a brass version of this for $8? If so it would be a better deal than that Parma brass chassis at $11. Brass is great for cutting and soldering, but the steel one will probably take more abuse and stay straight.
Slothead
slothead
The Doctor is IN!
slothead
The Doctor is IN!
Postby DHansen » Thu Jun 13, 2013 9:59 pm
I beleive that is just the lighting. I've never seen a brass Champion Thumper chassis before.
DHansen
Postby Dangermouse » Fri Jun 14, 2013 2:58 am
The extra bracing on Ninco is to stop the dreaded Ninco hop.
I think the torque in the motor causes the plastic chassis to flex too much and so she starts hopping (also don't know if I have ever seen a Ninco sidewinder??)
Before bracing
After bracing
I have braced most of my Ninco cars sometimes simply with a piece of plastic card cut to fit on the pan behind the motor and under the axle but usually with a piece of 90 degree angled aluminium cut to shape and glued up against the motor and onto the pan under the axle.
Works a treat.
My brother did the car in the video I think he just used a bit of hot glue (ok maybe a lot of hot glue :lol: )
David
Dangermouse
