Home Racing World • View topic - Vintage Scaley Repaint Help
Custom Paint Job Showcase
Postby chappyman66 » Fri Apr 12, 2013 11:10 pm
I have come into a small group of vintage Scaley cars with the "tupperware" bodies and snap in motors.
Are the rattlecan plastic primers good enough to give a basecoat on these cars?
Re: Vintage Scaley Repaint Help
Postby Cobra Freak » Sat May 18, 2013 7:14 am
If you ask 10 painters the same question, you'll get 10 answers :lol: If the detail on these older shells in coarse it probably won't matter, and I would say yes. What I don't like about rattle cans is that they are either on or off. I prefer the finer control an airbrush gives me, and I can lay down a thin coat that covers but does not obscure detail. :ugeek: but then, I'm fussy about painting!
Cobra Freak
Postby waaytoomuchintothis » Sat May 18, 2013 10:45 am
If you use Tamiya Fine Primer, its hard to cover up a detail. It just almost won't do it.
Postby Florida_Slotter » Sat May 18, 2013 1:22 pm
Postby Cobra Freak » Sun May 19, 2013 6:11 am
Well, in the worst case you'll get 10 answers four arguements and a fist fight! :mrgreen:
Cobra Freak
Postby dreinecke » Sun May 19, 2013 7:43 am
I see your fist fight and raise you to a duel!
The tupperware cars can be difficult to get adhesion on. I would use a 0000 steel wool to rough the body carefully and then prime. That'll give it something to bite into.
As for paints, I love air brushes, but always use automotive paints in a rattle can. Most of the Duplicolors go on light enough that hiding trim and details isn't a problem.
Postby waaytoomuchintothis » Sun May 19, 2013 10:49 am
Dave's right about the Duplicolor spray. I don't like using 1:1 paints for models because the pigment is too big and fills the details, but Duplicolor is significantly different. The pigment size is different for different colors, and some of them are very much like model paints at a bargain price. The Engine Enamel series has a low-gloss black that is perfect for convertible and vinyl tops. I used Duplicolor Engine Enamel to find a rare color for a Hudson, and the pigment was enormous. It was like I dipped the car in rubber. Lost so much detail it looked like a bad vac-formed body. You just have to experiment.
Postby chappyman66 » Sun Jun 02, 2013 10:31 pm
Thanks guys, I appreciate the input.
Return to The Paint Booth
