Home Racing World • View topic - *****Official 2020 F1 Proxy thread!!!*****
Re: *****Official 2020 F1 Proxy thread!!!*****
Postby Aloha » Thu Aug 29, 2019 4:31 pm
Oh boy the field just got even more competitive!!!! :)
Aloha
Dale
Aloha
Postby Mitch58 » Sun Sep 01, 2019 5:30 pm
Okay Zack,
I set up the car. That's a great motor choice for this car BTW. I never liked the Scaley motor in it, Mine tacked out at about 23K, too much.
I'll take #15.
Mitch58
Postby MOV41T » Sun Sep 01, 2019 7:48 pm
I’m trying to get me a short wheelbase car....
Put me down please
GAS41T aka MOV41T
ROSSKO
MOV41T
Postby BARC 1 » Thu Sep 05, 2019 12:03 am
Ok, I bought a Scalextrics McClaren from Austin and am setting it up for this race. I swapped motors to an18 K FF 50, amd added some weight.
What is the deal with the rear bushings? Do these have to remain stock or can they be replaced? I never saw anything in the rules specific to the bushings, so was looking for clarification.
Some photos from last years cars looked like brass bushings were OK to use?
Postby wanabgts » Thu Sep 05, 2019 9:31 am
wanabgts
Postby chrisguyw » Thu Sep 05, 2019 2:52 pm
# 17 for me please.
Chris Walker
chrisguyw
Postby BARC 1 » Thu Sep 05, 2019 8:24 pm
Today I spent some time on the BARC livery for the F1 event
Car is basically stock except for
Lower 19 K RPM FF50
Front axle tube
Slotting plus guide.
I needed to add a brass spacer on the rear axle to hold the crown gear in place as the motor shaft was too short
Added lead to end up with a car weight of 84 grams
Glued and trued the stock tires, and the car seems to run OK on my home track. I left the Nylon Bushings in place as the cars is smooth and chatter free. Didn't want to chance breaking the bushing mounts with one more snap in of the bushings. I was surprised how well it ran in this stock set up.
Postby JeremyC » Fri Sep 06, 2019 9:02 am
Would this car be eligible for competition?
https://www.scalextric.com/us-en/2018-w ... fw-41.html
JeremyC
Postby BARC 1 » Fri Sep 06, 2019 9:58 am
1. Scalextric Modern Formula 1 cars; those with the slimline IL motor configuration (2005-2017), but I've also heard that there were some slimline cars offered in the second half of 2004; if you have one of those, it's legal, too
As long as it is running a slimcan motors you are ok. You will have to swap out the factory motor. The factory motors turn about 24000 rpm, and you will want a motor running 18-19000 rpm.
Postby wanabgts » Fri Sep 06, 2019 2:47 pm
wanabgts
Postby midagekid1 » Tue Sep 17, 2019 1:54 pm
Please sign me up as this proxy was a blast!!!!!
midgekid1
midagekid1
Postby wanabgts » Thu Sep 19, 2019 11:15 am
wanabgts
Postby BARC 1 » Thu Sep 19, 2019 6:20 pm
The motor I added to my car was pulled out of my parts and has no markings on it. I checked with an rpm tester and it turns at 19300 rpm. @12 volts So is this going to be Ok?
I saw the spec on the other motors ,and they turn at 18-19K, but the one has twice the torque of the minnow, so if I have to buy one I was thinking of the MTL, although for all I know that is what I have in this car. Is there a way to identify the MTL’s
What did most car runs last year?
Postby midagekid1 » Wed Sep 25, 2019 10:57 am
Zac:
I always use the #15 so sign me up with that number.
Tom
midagekid1
midagekid1
Postby Aloha » Wed Sep 25, 2019 11:13 am
Lancelot will enter #7
Aloha
Dale
Aloha
Return to 2019 Formula 1 Proxy
Users browsing this forum: No registered users and 49 guests
