Home Racing World • View topic - Carrera or Scalextric Digital
Re: Carrera or Scalextric Digital
Postby BRS Hobbies » Tue Aug 06, 2019 12:15 pm
The switch is for changing the direction that the car travels. It's just easier than swapping the wires at the guide.
BRS Hobbies
Postby Fathead59 » Tue Aug 06, 2019 12:25 pm
That was what I thought , but wasn't sure . And since I am using the chassis for other builds I will just remove them . I plan on running a Scaletrix set up that is wireless , so if I need to wire up their chip to the car I will .
Fathead59
Postby Slotspeed » Wed Aug 07, 2019 3:37 am
Slotspeed
Postby Fathead59 » Wed Aug 07, 2019 9:28 am
Ok , I guess I will be keeping all of the chips/swicthes just in case I need them .
Fathead59
Postby b.yingling » Thu Aug 08, 2019 1:12 pm
b.yingling
Postby Slotspeed » Fri Aug 09, 2019 6:00 am
Then the IR receiver is on the wrong side of the rails
Slotspeed
Postby Fathead59 » Fri Aug 09, 2019 9:29 pm
I do have a couple of questions , can you match the old type of Scaletrix track with the new style ? And will the digital system work with the older style track ?
Fathead59
Postby Slotspeed » Sat Aug 10, 2019 4:46 am
Hi again,
My apologies because I didn't read your question about the switch properly. I thought you were talking about Carrera digital, but upon re-reading your particular post on page two of this subject I realised that you are talking about the small board with the direction switch of the Carrera analog cars. Well you can get away with removing it for analog, it is kind of useful if you want to run in the other direction without making wiring changes. It does have a couple of inductors on it which is possibly useful to prevent RF noise interfering with other domestic electronics but probably of little consequence if removed.
The other question about the older style of Scalextric track... Yes you can get adaptors, but the depth of the slot is slightly shallower and you will probably need to file the bottom of the guide on most of the newer cars to avoid interference with the bottom of the slot. It is however, a cheap source of track since I see people giving it away for free from time to time because of this limitation, and there is heaps of it around.
Must say this thread is a good read and interesting experiences shared regarding the Carrera and Scalextric digital systems. Sometimes this kind of discussion gets off the rails (so to speak) on some of the other forums, so its a credit to the members here for having a mature discussion about the pros and ams and cons and puns of each of the systems in question.
Slotspeed
Postby b.yingling » Sat Aug 10, 2019 6:24 pm
b.yingling
Postby Fathead59 » Sun Aug 11, 2019 5:09 pm
Ok , as long it just a directional switch it will not matter wheater it is in the car or not , I plan on using the chassis for other builds .
Fathead59
Postby Slotspeed » Tue Aug 13, 2019 6:21 pm
Slotspeed
Return to Digital Racing
