VW Baja Bus
VW Baja Bus
Postby VTECFOUR » Sun Jun 16, 2019 10:19 pm
Building a potential Holeshot Winter Nationals entry based on the old Monogram VW Baja Bus body. Spotted at the annual spring car model show n' sale, it was missing its two-piece side door/ramp along with the rear valence and both A-pillars were broken off and missing. At least the one-piece tinted window assembly was there.
Coincidentally, 3DRon, our club's 3D printing whiz was attending the show so I asked, "Could you scan the good side and reproduce a door?" With a quick look at the body, he responded resoundingly, "No problem".
So, here we are with the 3D printed one-piece filler with the body detail faithfully reproduced.
A big job nicely taken care of.
More body repair then painting and underpinning with a simple ladder chassis.
VTECFOUR
Re: VW Baja Bus
Postby VTECFOUR » Tue Jun 18, 2019 12:56 pm
Body repairs are coming along.
Stripped old decals, made up A pillars and rear valence from styrene and filled in some holes.
Chassis-wise going inline using either a 1/2" or 3/4" motor bracket.
VTECFOUR
Re: VW Baja Bus
Postby FC47 » Tue Jun 18, 2019 3:20 pm
Nice job bringing that along Dan, looking forward to seeing it done..
FC47
Re: VW Baja Bus
Postby VTECFOUR » Wed Jun 19, 2019 9:27 pm
Cut and shaped the ladder chassis pieces and gathered other parts.
- .055" piano wire for main rails and front axle uprights
- .064" brass strip for guide tongue and cross members
- 1/8" brass tube for front axle
- 5/32" brass tube for guide post
- JK inline offset motor pod, 3/4" wide
- rear axle oilites, 1/8" x 1/4"
- Cox crown gear for 1/8" axles (27 and 28 tooth to be tried)
- rear aluminum rims (unknown origin) with urethane tires and 1/8" axle
- front RS Slot RSW002 15 x 7 rims with PG tires and 3/32" axle
- resin wheel inserts replicating Cragar five-spokes
Mocked the wheels in position and played with ride height for this desired stance.
Body prep continues and chassis assembly next.
VTECFOUR
Re: VW Baja Bus
Postby VTECFOUR » Fri Jun 21, 2019 11:50 am
Chassis's rolling.
Pretty much my standard inline build so it'll go around corners too.
This is the stance once I figure out the body mounting.
VTECFOUR
Re: VW Baja Bus
Postby TuscoTodd » Sat Jun 22, 2019 6:09 am
Definitely a cool build and great way to salvage a damaged model body!
The 3D printed replacement door is a slick addition as well!
:text-bravo:
Re: VW Baja Bus
Postby chappyman66 » Sat Jun 22, 2019 8:39 am
Ok...first of all..... scanning and printing the other side.....SUPER cool. Yeah, it's mostly flat....but still..... awesome.
Second.... what a great build. Long and low, the Racing Bus. Sweet!
Re: VW Baja Bus
Postby VTECFOUR » Tue Jun 25, 2019 5:25 pm
Body's mounted with a slightly raked stance.
Chin spoiler needed some filing to just clear the track.
Affixed with single posts front and back, sitting in Sintra plastic crossmembers.
VTECFOUR
Re: VW Baja Bus
Postby Fast Co. » Tue Jun 25, 2019 5:31 pm
That thing is killer Dan!
Fast Co.
Re: VW Baja Bus
Postby noddaz » Tue Jun 25, 2019 7:35 pm
Heck yeah! Nice save there. And the 3D printed replacement panel is fantastic!
Scott
noddaz
Re: VW Baja Bus
Postby VTECFOUR » Wed Jun 26, 2019 6:52 pm
Chassis's powered though not the proxy spec motor for Expo class (Scale Auto 25K S can). Will get one but in the meantime, installed an Avant Slot Hurricane 25k boxer motor with 3:1 gearing (9t pinion, 27T crown).
With the proper motor, I'll play with gear ratios for the winter proxy's scale 1/8th mile (27.5 feet) dragstrip. Only track in my area with a long straightaway has an 18 footer. That'll have to do for testing.
Close to spraying primer on the body.
VTECFOUR
Re: VW Baja Bus
Postby VTECFOUR » Thu Jun 27, 2019 8:59 pm
Sprayed on Tamiya fine white primer.
A few spots need fixing but good on the whole.
Final coat will be back to orange with pearl.
VTECFOUR
Re: VW Baja Bus
Postby TuscoTodd » Thu Jun 27, 2019 11:08 pm
That is turning out GREAT!!!
Bravo!!
Re: VW Baja Bus
Postby CJR » Fri Jun 28, 2019 1:20 am
Been watching this from the start. Great build!
CJR
Re: VW Baja Bus
Postby chappyman66 » Fri Jun 28, 2019 8:32 am
Orange with pearl....how cool. Looks great!
