Digital for vintage chassis
1/24th Scale Slot Car Forum
"Home Of The Big Ones!"
Postby Markalign » Thu Apr 11, 2019 9:12 am
Hi, has any one fitted a carerra digital chip to a cox, monogram or revell chassis for use on carerra digital track.
Markalign
Re: Digital for vintage chassis
Postby dw5555 » Thu Apr 11, 2019 9:22 am
The 732 chip fit exactly between the frame rails. Just hot glued in. Works great.
Dave
dw5555
Postby Markalign » Thu Apr 11, 2019 12:09 pm
Thanks for sharing, what power pack are you using and what controller? I ask as the motor in the chassis looks very similar to that used in the cox mag frame cars
Markalign
Postby dw5555 » Thu Apr 11, 2019 1:16 pm
Stock Carrera digital controller. I have about 7-8 of these vintage cars but I don't remember what these motors are rated at (Original owner since the 60's) I have an adjustable power supply on the track with it running 17V. I run it that high to make up for any lazy L/C's that I might have. I adj the speed at the CU. I haven't run it a lot but it runs good. Turns out the stock Carrera 1/24 wheels will fit on the axles. I just screwed em on using just a little force. Need to find some SUPER low profile front tires to fit these rims.
Dave
dw5555
Postby Markalign » Sat Apr 13, 2019 5:36 pm
Thanks,ill post pics when im done
Markalign
Postby noddaz » Sun May 26, 2019 6:46 pm
How do you keep it from shorting out on the chassis?
Scott
noddaz
Postby dw5555 » Mon May 27, 2019 9:05 am
These older chassis sit about 1/4" off the track so there is no danger of shorting. I was worried about the same thing until I saw it.
Dave
dw5555
Return to HRW 1/24 Scale
