Removing Lettering From H&R Tires
1/24th Scale Slot Car Forum
"Home Of The Big Ones!"
Postby PinkPig23 » Fri Apr 05, 2019 8:54 pm
I’m sure I’m making this more difficult than it needs to be.
I’m working on a project where I’d like to remove the “H&R Racing” from the side walls of a set of H&R silicone tires. So far I’ve tried acetone, isopropyl alcohol, and even contact cleaner, and none of them made a dent with removing the lettering. Am I missing something here? What else can I try to remove the lettering? Do I have to sand them off?
PinkPig23
Re: Removing Lettering From H&R Tires
Postby waaytoomuchintothis » Fri Apr 05, 2019 9:29 pm
Just sand the lettering off...
Postby BIG E » Tue May 07, 2019 11:55 am
I rub off the lettering on the Daytona Pro Track tires with a rag (usually an old cotton T shirt) and good old Ronsonol lighter fluid.
Works great and clean every time, especially if you do it before using the tires. Should work the same on Gene's H&R tires, too.
Hope this gives you another option. -- Ernie :>)
BIG E
Return to HRW 1/24 Scale
