Home Racing World • View topic - fat flared Ford Escort Mk. 1
For 1/32nd Scale Models
Postby VTECFOUR » Thu Apr 04, 2019 12:55 am
Cast a fat flared Ford Escort Mk. 1 body, so preparing an adjust-o-wheelbase chassis metal chassis like many of my small car builds.
Component list consists of:
- .064" brass guide tongue
- 5/32" brass guide post tube
- 1/8" brass front axle tube
- 3/32" brass square front axle supports
- 3/32" brass square tube main rails
- .064" brass front cross member
- .064" brass rear cross member
- .064" brass side pans
- .062" piano wire front assembly sliders
Will be motorized with a slimline FF050 motor held in a 3d printed motor pod.
Should be together soon.
VTECFOUR
Re: fat flared Ford Escort Mk. 1
Postby VTECFOUR » Fri Apr 05, 2019 4:02 pm
Good progress.
Trimmed the body down to a light 9 grams. Assembled the chassis and attached the slimline motor pod. Using a Sloting Plus guide, my go-to one these days.
Should be rolling by the weekend.
VTECFOUR
Postby VTECFOUR » Sat Apr 06, 2019 7:07 pm
Chassis's rolling with Slot It 15 x 8 plastic rims/Slot It rubber tires at the front and Slot It F1 rims/home made urethanes in the back.
Body's mocked on.
Final stance will be close to this. I like the tucked-in tire, low stance look.
VTECFOUR
Postby VTECFOUR » Sat Apr 06, 2019 9:56 pm
Body's mounted, single posts at the front and rear.
Got a pretty low stance in the end.
VTECFOUR
Postby F1Fan » Sat Apr 06, 2019 10:59 pm
......and now for the rest of the story!
I love the look of this car, great job Dan!
It was I who asked "Flare Master" Dan to help me with this car and especially the flares, the reason are these decals I bought from Tailormadedecals.com
I have always been a fan of the Lucky Strike livery and loved this Escort since the first time I saw it. I am looking forward to getting the car and finishing the painting and decals, hopefully I can do Dan's amazing work justice!
Chris
F1Fan
Postby VTECFOUR » Sun Apr 07, 2019 4:04 pm
Hi Chris,
Working on your Scalextric Escort body is the catalyst for this build, so thanks for that. I hadn't done flares with epoxy in a long while. They turned out so well that I had to make a mold from your "master". Your Escort has solid epoxy flares so they'll have to be hollowed out with a cone sanding bit to get a similar tucked-in tire stance. Frankly, if I never build flares again, I won't miss it!
In the meantime, got this build's chassis drivetrain (Scalextric Sport FF050, 25K, BWA 9t pinion, Slot It 28t crown) installed...
...and added sidepans with the body sills trimmed for clearance.
It's tight but I managed just a tiny bit of clearance at all the wheel arches so as not have tire rub.
Runs well on my test track, but have to give it a better workout on Luf's Big Targa track.
Paint-wise, I'm thinking a Camel Yellow finish with the appropriate decals would look good.
VTECFOUR
Postby VTECFOUR » Mon Apr 08, 2019 5:58 pm
Sprayed on Tamiya white primer and installed Slot It Jaguar XJR9 wheel inserts.
Tamiya Camel Yellow to follow.
VTECFOUR
Postby historiceng » Mon Apr 08, 2019 6:13 pm
That is a really nice looking build, very nice !
historiceng
Postby MrAdept » Tue Apr 09, 2019 11:15 am
Very nice, up to your usual high standards.
Mark
MrAdept
Postby dge467 » Tue Apr 09, 2019 8:45 pm
That is really cool!
Postby SuperSlab » Tue Apr 09, 2019 9:01 pm
SuperSlab
Postby VTECFOUR » Thu Apr 11, 2019 4:35 pm
Sprayed on Tamiya TS-47 Chrome Yellow which looks more like a Camel Yellow tone. Much darker than the lighter yellow represented on the can's cap.
I knew that this was the tone I'd get this time after painting my 1/25 Sunbeam Tiger build. Wonder if someone at the factory put on the wrong cap?
Paint detail, glass, interior tray to come.
VTECFOUR
Postby dreinecke » Thu Apr 11, 2019 8:22 pm
I LOVE that! Very cool looking Escort!
Postby VTECFOUR » Wed Apr 24, 2019 10:30 am
The decalling and paint detail seemed to take forever, but got it done.
Installing vac formed windscreens and interior driver tray left to do.
VTECFOUR
Postby VTECFOUR » Fri Apr 26, 2019 11:42 am
Done!
Tamiya semi gloss clear applied but did crinkle a few decals. Vac formed windscreens were off a bit but resulting coverage works good enough. Interior tray mounted on top of motor.
Goes well on the little test track but tonight's run on Luf's Big Targa will reveal all.
VTECFOUR
Return to 1/32 Showcase
