Home Racing World • View topic - The Builds!
The Builds!
The PREMIER Slot Car Drag Racing Event!
Forum rules
[url=http://www.homeracingworld.us/viewtopic.php?f=78&t=20296][/url]
Re: The Builds!
Postby BARC 1 » Thu Mar 07, 2019 1:25 pm
No bearings? What is with the adversion to bearings. Seems every proxy specifies this. The cost of 3/32 bearings is less than bushings..
I use bearings on all my builds, and just noticed this no bearing thing again. So it is back to the soldering table to remove bearings and install bushings, which in all likelyhood makes zero difference. I suspect the varience in motor rpms between motors makes a bigger difference then bearings vs bushing do.
Just raising the flag on a rule that seems pointless IMO.
Oh well
Re: The Builds!
Postby BARC 1 » Thu Mar 07, 2019 3:20 pm
Here is my first attempt at a drag car. A 1966 Mustang with a scratchbuilt Brass chassis. Big Paul gage urethanes used on the back that were salvaged from a Sportsman car, as was the motor and the shell.
Wheels lift on take off, and that is all I know. Will send this in and wait on feedback as my straight at home is only 12 feet.
Re: The Builds!
Postby BARC 1 » Fri Mar 08, 2019 1:08 am
Was asked to share where I get my 3/32 bearings so cheap.
Just search ebay Minature flanged bearings FR133ZZ. $1.00 a bearing,free shipping.
Multiple asian venders selling these. The part number is what helps the search find the exact flanged bearings you need for a 3/32 axle.
Re: The Builds!
Postby teamwild » Fri Mar 08, 2019 8:05 am
I have a few cars with bearings as ProTrack used to use them on their chassis kits. Haven't really seen a big advantage with them, maybe on an endurance or extended proxy event but for what we're doing here with drags probably not a big advantage. I think bearings are viewed as overly expensive, I've never looked into getting them but looks like you can find them pretty reasonable, or expensive, need to be careful where you buy, especially on amazon/ebay.
FR144zz will get you the 1/8x1/4 too.
Love the Mustang, Nice Job!
Looks like my first project is going to be a 1/24 '66 El Camino Gasser :banana-dance:
Matt
teamwild
Re: The Builds!
Postby TuscoTodd » Fri Mar 08, 2019 9:42 am
Dan - That Mustang definitely looks like she'll be a runner!
Looking forward to seeing it pull the wheels and head nose up off the line in some heads up - wheels up gasser action!!! :D
Matt - Looking forward to seeing pics of teh El Camino build!
Re: The Builds!
Postby Foamy » Fri Mar 08, 2019 11:51 am
Like Dan posted, bearings are $1.25 each at avidrc.com. Metric and Imperial sizes. I have used these for years with zero failures. Seems to be no difference on track between these and the $22.00 jobs from the Raceway. There is a measured speed difference on the Drag Strip between the Avid bearings and bushings.
Hot Rods anyone? Starting on my heap tomorrow...
Foamy
Re: The Builds!
Postby TuscoTodd » Fri Mar 08, 2019 2:46 pm
Well - maybe for a future run of this proxy we will allow them - however, for now, they are only allowed in the EXPO class.
Re: The Builds!
Postby TuscoTodd » Fri Mar 08, 2019 3:03 pm
Re: The Builds!
Postby sadco racing » Fri Mar 08, 2019 8:11 pm
Throwing this 63 Vette in the mix. Dressed the body up a bit. Not totally sure about the chassis yet but kicking around a couple of ideas. (Sorry if the pics are giant, first time I’ve done this from my phone)
sadco racing
Re: The Builds!
Postby FC47 » Fri Mar 08, 2019 9:01 pm
Foamy that Stingray almost made me drool,
My 63 did time as a drag car in the mid 70's..
Sadco, I can't wait to see that built!
:banana-dance:
FC47
Re: The Builds!
Postby noddaz » Fri Mar 08, 2019 9:07 pm
Dan, you can fix that.. Put a small wing on the front and then the guide will be "under the body"... lol
Scott
noddaz
Re: The Builds!
Postby nhdungeonracer » Sat Mar 09, 2019 10:20 am
Re: The Builds!
Postby TuscoTodd » Sat Mar 09, 2019 10:48 am
That Vette is looking MEAN!
:handgestures-thumbup:
Re: The Builds!
Postby bookie » Fri Mar 15, 2019 3:35 pm
bookie
Re: The Builds!
Postby TuscoTodd » Fri Mar 15, 2019 3:43 pm
Oh that is going to be cool!!!!
:D
Return to HRW HOLESHOT NATIONALS!
