Owens Corning 427 Corvette
Postby VTECFOUR » Mon Mar 04, 2019 1:45 am
Liking the bigger scale more and more, so got this Monogram kit out of the closet and gathered running parts.
BRM Trans Am rims and tires match the kit's wheel/tires diameter spot on. With a little filing, the wheel insert will fit right in.
The engine hood and rear flares fit well and were glued to the body.
Would like to try a hybrid sidewinder chassis on this one.
VTECFOUR
Re: Owens Corning 427 Corvette
Postby btaylor » Mon Mar 04, 2019 8:01 am
It makes one heck of a good slot car!
Postby VTECFOUR » Mon Mar 04, 2019 12:54 pm
I was wondering if the rear quarter decal covered the added flare, so now I know.
Thanks for posting.
VTECFOUR
Postby VTECFOUR » Thu Mar 07, 2019 9:00 pm
Cut and gathered pieces for an inline ladder-type chassis.
- .055" piano wire for main rails and front axle uprights
- .032"x .75" brass strip for rear and middle crossmembers
- .064" x .75" brass strip for guide tongue
- Slot It 20.5k Flat 6 motor
- Slot It 10t pinion gear and Plafit/Sigma 30t crown gear for 3mm axle
- Sloting Plus 3mm axle
- Sloting Plus 3mm rear axle bushings.
- JK F1 motor pod (.75" wide)
- Scale Auto universal guide with Samson guide post
Should be together soon.
VTECFOUR
Postby TuscoTodd » Fri Mar 08, 2019 7:28 am
Great to see the "parts list" associated with the build!
Looking forward to seeing it's progression!
Postby VTECFOUR » Fri Mar 08, 2019 1:36 pm
Filed and sanded down the kit's wheels into inserts.
Fit well.
Flat black on the spokes to come. May do aluminum on the chrome.
VTECFOUR
Postby TuscoTodd » Fri Mar 08, 2019 2:49 pm
Inserts are turning out nice! Dig the fact that they look to even include the valve stem!
Postby VTECFOUR » Sun Mar 10, 2019 3:28 pm
Basic ladder chassis pieces soldered together.
Getting some 4mm brass tube to accept the 3mm (.118") front axle.
Could use 5/32" tube with an inside diameter of .125" but rather minimize any slop.
VTECFOUR
Postby VTECFOUR » Wed Mar 13, 2019 12:22 pm
Chassis's rolling.
Mocked the body on.
Looking for a final stance with the body slightly higher and the wheels/tires tucked in.
VTECFOUR
Postby VTECFOUR » Wed Mar 13, 2019 1:45 pm
Body's mounted.
Not too slammed which is my tendency.
On to getting the chassis powered.
VTECFOUR
Postby VTECFOUR » Thu Mar 14, 2019 10:52 pm
Running chassis's assembled.
Crown gear was a real tight fit. Required installing the bushings with the thin flange on the inside and reducing the width of the gear's boss.
Worked out so there's no rubbing.
In tight corners I could see the front tires hopping. They're pretty wide so a coating of Sally Hansen's Hard as Nails, Invisible 109 nail polish cut down the friction and eliminated the hop.
Runs fine.
VTECFOUR
Postby VTECFOUR » Tue Mar 19, 2019 10:35 am
Interior tray modified to accept the chassis. Kit didn't provide a driver figure, so a Fujimi kit one was prepared.
Being an open cockpit car, the driver figure was a must for me.
VTECFOUR
Postby VTECFOUR » Tue Mar 19, 2019 7:38 pm
Cockpit test fitted.
Works for me.
On to finishing the body.
VTECFOUR
Postby VTECFOUR » Sat Mar 23, 2019 1:52 am
Ended up with Plan B on the paint and decals. Applying the kit's Owens Corning rear quarter panel decal was disastrous. Wouldn't conform to the wheel arch flare even with decal softener and cracked into pieces.
Sprayed on Tamiya TS-16 Yellow and covered with the kit's number decals and sponsors from a Nascar kit.
Turned out well enough.
All that's left are the wheel inserts. Kit's Torque Thrust-like five spoke wheel inserts are presently being used for a mold but I've got some BRM mini lite inserts in the mail. Not sure which I'll use but they'll be highlighted in the same gray as the exhaust pipes.
On to the next build.
VTECFOUR
Postby FC47 » Sat Mar 23, 2019 5:55 am
:text-coolphotos:
It's really sharp Dan! Turned out perfect over all!!
Well done man!
FC47
