Ferrari 312P Spyder
For 1/32nd Scale Models
Ferrari 312P Spyder
Postby VTECFOUR » Fri Feb 22, 2019 2:19 pm
My coupe turned out well, so I'm giving a Spyder version a go.
Cut the roof off one of my resin casts and covered the gap with an undersheet of thin .015" styrene sheet to conform to the subtle body curves.
Glued in another .015" sheet this time shaped and fitted to closely fill the opening.
Working out so far.
VTECFOUR
Re: Ferrari 312P Spyder
Postby VTECFOUR » Sat Feb 23, 2019 1:55 am
Opened up the cockpit in the filler plate. Mocked the body on my Coupe's chassis.
That helps to visualize the outcome.
Works for me.
VTECFOUR
Postby TuscoTodd » Sat Feb 23, 2019 6:51 am
That is going to be very cool! Like the progress pics!
Postby 32lbking » Sat Feb 23, 2019 12:25 pm
That's looking pretty sweet. What glue do you use to glue the styrene to resin ?
Randy
32lbking
Postby VTECFOUR » Sat Feb 23, 2019 3:47 pm
Applied Lepage Super Glue Ultra Gel after sanding both glued surfaces.
Reinforced the underplate with JB Weld fast setting epoxy for some extra strength.
VTECFOUR
Postby chappyman66 » Sat Feb 23, 2019 3:49 pm
Nice work....I enjoy your builds.
Postby VTECFOUR » Sun Feb 24, 2019 2:04 am
Fabricated the snorkel intake from Sintra plastic and resin. The small rollbar was bent from aluminum tubing.
Puttying the seams is next and while it's drying the chassis fabrication begins. Going to build one of my inline FF050-motored hybrid adjust-o-wheelbase chassis. Want to see how it performs in comparison to a S can hybrid sidewinder chassis that's under my Coupe.
VTECFOUR
Postby Dogsbody » Sun Feb 24, 2019 9:18 am
Nice work!
Dogsbody
Postby VTECFOUR » Sun Feb 24, 2019 7:09 pm
The first rollbar wasn't sitting well with me so a new hoop out of piano wire was bent and re-positioned.
That's better.
VTECFOUR
Postby VTECFOUR » Wed Feb 27, 2019 9:32 pm
While the body putty's drying, I got the basic adjust-o-wheelbase chassis assembled. The FF050 motor pod's a 3D printed one, custom drawn for me that accepts Parma oilites.
I've been favoring the Sloting Plus Universal rounded keel guide lately instead of the red Scale Auto one. The lap counter in-slot sensors on some of the tracks at GVSCC do not recognize the red color for some reason.
VTECFOUR
Postby Broman62 » Wed Feb 27, 2019 9:45 pm
I see another beauty on its way...always enjoy your builds V!!! :auto-layrubber: :auto-layrubber: :auto-layrubber:
Postby munter » Thu Feb 28, 2019 5:34 pm
where is the like button?
munter
Postby VTECFOUR » Thu Feb 28, 2019 6:29 pm
Chassis's rolling and body's mounted with single posts at the front and back.
Stance is good.
VTECFOUR
Postby VTECFOUR » Fri Mar 01, 2019 2:13 am
Chassis's fully constructed now.
Will be running under power soon.
VTECFOUR
Postby VTECFOUR » Sat Mar 02, 2019 2:46 pm
Chassis's rolling and running.
Body's mounted and looking good to me. Pretty low slung in the cockpit area so the driver figure will likely be on top of the slimline motor.
VTECFOUR
Return to 1/32 Showcase
