I had to try my hand at this 3D chassis building. I found a file I liked for a universal chassis, and another one for a beefed up Motor pod. The pod is designed for bronze axle bushings, and has reinforcement ribs in the motor area and at the axle mounts. I had some SCC stock car aluminum wheels in 15x8 and 15 x10, so I used them along with my own urethane tires. I used a slot it orange end bell motor, and 9/27 gearing. the guide is a slot it also. The body is an old FLY corvette that was languishing in my parts bin, and interior pod was cut down from an unknown source. As a FLY car, it was not much in the running department, so I had no where to go but up with this one. As it turned out, I built one great handling, VERY quiet, and super fast machine. It is currently turning low 7.00 second laps, on an 8.00 second lap average course. Not bad for a homespun hotrod!
My next attempt. is to build a FLY Marcos in a similar fashion. I always liked that body, but the front motor set up just didn't cut it for me.
