Front Drive slot car drive shaft replacement
Postby John R » Thu Dec 20, 2018 8:19 pm
I have a Scalextric Front motor Viper I need to replace the drive shaft on. Are there any videos on removing and installing them. Anyone have any tricks or tips?
John
John R
Re: Front Drive slot car drive shaft replacement
Postby Wobble » Fri Dec 21, 2018 4:04 am
I found a lollipop stick that is a plastic tube which is a perfect fir on the motor shaft and I used a bit of that to replace the spring. I turned the shaft around so the splined end was at the motor end and used a brass pinion instead. It made for a quieter runner.
Wobble
Postby John R » Sat Dec 22, 2018 11:35 am
I have a replacement shaft with spring. Is there ant trick to removing the old one and putting the new one on?
John
John R
Postby Wobble » Sat Dec 22, 2018 1:45 pm
To get the old one off I just used needle nose pliers and prize the spring off a small bit at a time while gradually moving the pliers in from the pointy end to the thicker end (if that makes sense). Measure the overall length of the original and I just squeezed it on in a vice until it was the correct length. If you're going to use the spring you might find it better to put it on the motor 1st because the spline on the shaft makes it a bit more difficult to slide on.
Wobble
Postby Cincyslots » Sun Dec 23, 2018 9:54 am
I should have a new pack of springs if you need them. I’ll know for sure Wednesday.
Bruce
Cincyslots
Postby FC47 » Sun Dec 23, 2018 10:09 am
When I change em, I hold the drive or motor shaft with a needle nose, and twist the spring with my fingers in a threading direction which opens or relieves the gripping pressure of the spring coils and with a bit of pulling apart pressure of the two the spring easily leaves the shaft. Mindful of the location position of the spring and shaft- hold the driveshaft again with pliers, and 'thread' that buggar back on twisting with your fingers. Repeat either to perfect the location you are happy with
FC47
Postby waaytoomuchintothis » Sun Dec 23, 2018 12:53 pm
I don't like the spring at all. I hold the motor shaft with needle nose pliers and pull the spring off, wrecking it. I use a section of an old ballpoint pen cartridge as a superior replacement, as many of us have done on HRW after Harry came up with it. I have also used clear vinyl tubing.
Postby Fletch3 » Sun Dec 23, 2018 3:39 pm
+1 on the ball point pen. The bic pens I use have a clear cartridge and slide on nicely. The springs give a vibration and there heavy which takes more torque to turn. I just did a Scaley Viper and it runs great now.
Fletch3
Postby PetesLightKits » Mon Dec 24, 2018 10:02 am
I used a section of 18 gauge (speaker/household) wire insulation/sheathing with the copper wire strands removed. Works with lower powered cars and is slightly more flexible than some of the other alternatives.
Peter
PetesLightKits
Postby waaytoomuchintothis » Mon Dec 24, 2018 11:21 am
Yep. That's just like the vinyl tubing.
