Home Racing World • View topic - Snyderville Speedway
SHOW YOUR SLOT CAR TRACK!
Re: Snyderville Speedway
Postby Josh S » Thu Nov 08, 2018 11:10 am
Josh S
Postby slothead » Thu Nov 08, 2018 6:48 pm
Very nice video - it was easy to follow the cars and see where positions were being challenged and defended. The speeds were realistic and the lack of crashes refreshing.
If you race regularly and keep track of points toward a championship, consider inverting the starting grid so the top car has to work their way through the field in subsequent races. It also keeps the cars trailing in points motivated because starting out front means a good clean race could result in a win or podium finish.
slothead
The Doctor is IN!
Postby Josh S » Fri Nov 09, 2018 9:06 am
Josh S
Postby Josh S » Sat Nov 10, 2018 8:23 am
Josh S
Postby Josh S » Tue Nov 13, 2018 6:15 pm
Josh S
Postby Josh S » Wed Nov 14, 2018 6:50 pm
Josh S
Postby Josh S » Sat Nov 17, 2018 7:27 pm
Josh S
Postby Josh S » Fri Nov 23, 2018 7:00 am
Josh S
Postby Josh S » Sun Nov 25, 2018 9:17 pm
Josh S
Postby slothead » Mon Nov 26, 2018 12:02 pm
Eric get 2 laps in the penalty box for aggressive driving.
slothead
The Doctor is IN!
Postby Josh S » Mon Nov 26, 2018 4:15 pm
Josh S
Postby BRS Hobbies » Mon Nov 26, 2018 4:43 pm
First off the track looks amazing!
At some point you might consider going to a crash and burn format or a modified crash and burn format. Some do a lot of shorter races and if your car leaves the slot, than your out for the rest of the race. You can have a point system for each race and then total up all the points for the final results. Another way to do it is modified crash and burn that gives each driver a certain number of deslots until they are out of the race. You can use playing cars or poker chips that can be turned in each time for a deslot. When you run out, your out of the race. This kind of racing may have a learning curve with the drivers but in the end, the racing will have a really nice flow to it without having to start and stop the race all the time.
I have also seen self marshalling work as well. If your car leaves the slot, then you have to go and put it back on the track yourself. With wireless controllers it can be done fairly easy as long as everyone has access around the track. The only time the race would be stopped is if a car is blocking one of the lanes, otherwise you keep racing. Generally, the driving gets better since most get tired of having to get the car plus it costs you a lot of time in the race which makes you think twice about driving too aggressively.
In the end, the racing should have a nice flow and the less track calls the better since it allows each driver to get in a rhythm.
Brian
BRS Hobbies
Postby Josh S » Wed Nov 28, 2018 9:17 pm
Josh S
Postby Josh S » Thu Nov 29, 2018 5:48 am
Josh S
Postby proxieken » Thu Nov 29, 2018 6:15 am
Thanks for making the videos. They were great with the commentary. The painted track is really a nice layout and looks better than black by quite a lot. What is the tiny screen in the upper right corner? Is that the phone used for race management?
proxieken
Return to Reader's Roads
