Re: What's on your bench right now? [1/43]
Postby LloydL » Sat Nov 03, 2018 5:22 pm
Great idea Aki, it is good to start from scratch!
Regards, Lloyd.
LloydL
Postby pfuetze » Sun Nov 04, 2018 1:41 am
cool table with a nice size, Aki!
going wood this time? ;-p
Postby taskak » Sun Nov 04, 2018 9:37 am
As much as I would like to try to build a routed wood track
it's just that I got way, way too many cars with magnets that wouldn't work on wood track.
It would take hundreds of tires and guides to tune them all
so it's gonna be painted Carrera GO track with aprons, same scenery stuff than before but not the lights.
Lights were nice but made cleaning the track very difficult, they stuck to sleeve and snap broken too easily too.
Table allows to build a 2.5 meter long straight and I was thinking about maybe setting up first one meter long straight
then banked curve and then the the 2.5 meter straight.
Rest of the track would be with more curves, so it would resemble little bit of Indianapolis F1 track.
taskak
Postby taskak » Wed Nov 07, 2018 10:59 am
taskak
Postby BRS Hobbies » Wed Nov 07, 2018 1:08 pm
Nice job on the track! It looks to be fast with the long straightaways. Have you decided on what your going to use for the aprons?
Brian
BRS Hobbies
Postby LloydL » Wed Nov 07, 2018 7:28 pm
Aki, I was amazed at the difference after I painted my plastic track with flat emulsion house paint, also known as latex. I do not run magnets and all of my cars suddenly became very drivable, even Carrera GO cars with pin guides and standard tyres! But I do run reduced voltage.
Regards, Lloyd.
LloydL
Postby taskak » Thu Nov 08, 2018 11:07 am
taskak
Postby pfuetze » Sat Nov 10, 2018 6:26 am
in the picture 3 posts above - the lower left corner, which is connected with short straights - it that a R2 or an R3?
because the short straights do no good when driving no magnet ...
if it is an R2 i would exchange these short straights and the R2 against an R3 if thatt´s possible. just for the flow of driving ....
nice first aproned corner!
Postby taskak » Sat Nov 10, 2018 9:20 am
taskak
Postby pfuetze » Mon Nov 12, 2018 3:18 pm
you´re most welcome, Aki!
everything for the flow and speed :-)
Postby taskak » Fri Nov 30, 2018 3:52 pm
taskak
Postby LloydL » Sat Dec 01, 2018 2:11 am
It is looking good Aki!
Regards, Lloyd
LloydL
Postby pfuetze » Sat Dec 01, 2018 2:28 am
oh yeah!
THAT looks like it has some nice flow in it!
great looking layout, Aki!
one PS for each lane is a good idea IMO and with 0-30V, 3A you are on a very good base, should be sufficient for anything with 1/43rd wheels!
Nice aprons, i hope there are long enough after the turns ... some cars tend to move even 1ft (30cm) after the turn ...
Postby pfuetze » Sat Dec 08, 2018 9:41 am
first print of the 4WD chassis - looks good to me.
gearing 15/8 on 2mm axles seem to run nice.
i forgot to order wheels! silly me.
Postby LloydL » Sun Dec 09, 2018 6:36 am
This looks amazing Peter!
Regards, Lloyd.
LloydL
