Home Racing World • View topic - Carrera head light question
Postby tracyridge » Wed Oct 31, 2018 12:59 pm
Hi...
I was wondering if anyone knows if the Carrera digital head light whip is available on its own, or is it, like I suspect, only available with a chip?
Thank you
John
tracyridge
Re: Carrera head light question
Postby dw5555 » Wed Oct 31, 2018 1:23 pm
What is a whip? :think:
Dave
dw5555
Postby tracyridge » Wed Oct 31, 2018 2:52 pm
the whip ...the tiny circuit board that has the LED lights on it and a short piece of wire with the male end plug on it..that plugs into the chip...….. did not know the name for it so I used a term I have heard electricians use on job sites to describe similar pieces of equipment , though much much larger!
John
tracyridge
Postby MrAdept » Wed Oct 31, 2018 4:21 pm
Generally they are not available outside of the car itself. You may find someone has parted them out of a digital car if they are converting it to analog.
The digital boards don't come with the lights.
Alternatively you could make up some from LEDs and resistors...
Mark
MrAdept
Postby dw5555 » Wed Oct 31, 2018 6:03 pm
If you don't mind not having the board you can just hot glue 3V led's into the headlight sockets and connect them to the chip. I have done this many many times to Carrera and non Carrera cars to add lights. The digital chip itself is the resistor.
Dave
dw5555
Postby Cincyslots » Thu Nov 01, 2018 5:53 am
What car are you working on? We may have the spare part you need.
Bruce
Cincyslots
Postby tracyridge » Thu Nov 01, 2018 8:07 pm
Hey Bruce, ...well I have at least a dozen cars I would like to put lights in,,,,, so chances are I will take what you have and make them work one way or another.....
john
tracyridge
Postby Cincyslots » Fri Nov 02, 2018 5:26 am
Cincyslots
Return to Digital Racing
