Home Racing World • View topic - scalextric McLaren F1 GTR
Postby docdoom » Tue Oct 09, 2018 10:10 pm
One is for Dave Kennedy. can you give a detail on what the motor drive train set up is going to be on these cars. sp or slim can?
docdoom
Re: scalextric McLaren F1 GTR
Postby Modlerbob » Sat Oct 20, 2018 12:22 pm
I am eagerly waiting for the scaley version of this car. I am assuming it will have the new inline drive train. Supposed to hit the stores in December. It would be bad marketing if it misses the Christmas market.
Postby DaveKennedy » Sun Oct 21, 2018 9:46 am
I'll find out.
My photos of the prototypes early this year. Sadly I had to return them to the homeoffice.
Postby Racie35 » Sun Oct 21, 2018 8:41 pm
Dave how did you not notice motor configuration while you had them?
Racie35
Postby DaveKennedy » Mon Oct 22, 2018 8:48 am
Postby DaveKennedy » Tue Oct 23, 2018 6:31 am
**** EDIT*****
This car has the FF (slimcan) motor I'm told. BTW I've gotten the specs on that motor and it's only rated 1000 rpm higher than the standard motor. So it's essentially the same spec as the regular FC motor.
Needed more time to wake up before answering this today... sorry... FF slimcan motor NOT big block FK.
Postby Dangermouse » Tue Oct 23, 2018 6:53 am
FK motor??
That is a step in another direction for Scalextric
Ninco used FK motors long can (eg NC5) and short can (NC8)
Or is it the slim FF050 motor the same as in the Ford MkIV
If so it will be a quick car. In my experience scalextric ff motors are approx 23k. Being FF it won’t be an even runner with other GT cars that have an FC motor in them
Dangermouse
Postby DaveKennedy » Tue Oct 23, 2018 6:55 pm
Ok... this is my fault... I was sleepy and made a mistake... FF slimcan motor NOT FK.... sorry.
Postby Modlerbob » Mon Oct 29, 2018 12:03 pm
I don't understand Scalextric's decision to go with a "FF" motor. Both Slot.It and MrSlotcar were able to fit the more standard size motors FC and FT inside the car with more or less complete interiors. In slot.it's case inline while MrSlotcar used an anglewinder setup.
Postby DaveKennedy » Mon Oct 29, 2018 12:49 pm
Postby Modlerbob » Mon Oct 29, 2018 3:21 pm
I could fit the Mrslotcat short body over the slot.it chassis as the wheel base is the same
Postby DaveKennedy » Mon Oct 29, 2018 3:25 pm
Still a different car... if you want to not accept what I've said about it being a clearance issue you're welcome to ignore me.
Postby Modlerbob » Mon Oct 29, 2018 11:43 pm
I'll be content to wait and see. I have several of the slot.it long tail version, two of the MrSlotcar short tail version and even one of the Ninco short tail version. I will be getting at least one of the new Scalextric version but depending on how it runs there may be only one in my stable.
Postby Modlerbob » Sat Dec 08, 2018 12:37 pm
My new Scaley F1GTR sure enough has the new inline configuration just like the GT3 cars but it has the standard FC-130 motor, not the smaller slimline FF motor. Plenty of room inside for the interior.
Postby Modlerbob » Sat Dec 08, 2018 3:21 pm
