Home Racing World • View topic - Where to shop for Resin Cars
Re: Where to shop for Resin Cars
Postby Fathead59 » Sun Jul 29, 2018 7:23 pm
Harry, it doesn't have to be that trim because I would be making it as a stock car anyway, and besides I have a 1/24 scale model that I am making into a drag car anyway , so it is all good , the only thing I would need to know is what kind of chassis will work with the car , with RMS , he had a type of chassis that would work with each car , and because of a stroke , I am limited with how much I can do, but always am pushing my self to do more. Thanks for any info, the more I get the better.
Fathead59
Postby HomeRacingWorld » Sun Jul 29, 2018 8:24 pm
With the cars I am going to change/mold, it will be mostly a scratchbuild chassis affair. OR a good adjustable like the Slot.it HRS2. OR you could cut/splice other chassis you have.
Postby Fathead59 » Tue Jul 31, 2018 12:40 pm
Thanks for all of the info slothead , with use as much info I can get
Fathead59
Postby Fathead59 » Wed Aug 01, 2018 5:37 pm
And I am just getting back into slot cars from when I was a kid, will be hitting 60 soon, I just wanted to do something to keep my mind off of all the things I lost from my stroke. Working on the slot cars just keeps me grounded( besides being fun ). Had a lot of Ho size cars and track, would still like to have that track but where I live I have limited space.
Fathead59
Postby Fathead59 » Wed Aug 01, 2018 6:17 pm
When I got the 4 bodies Dave at RMS said to use Monogram chassis which I have because he placed the mounting area where the screws would go, maybe that will be the same with what Harry will do
Fathead59
Postby Fathead59 » Wed Aug 01, 2018 7:58 pm
My plan is to build a Scaletrix track set and run them as digital cars, I think one set you can run 4 to 6 cars wirelessly , but like I said when I get my RSM cars done those will only be ran by me, or be boxed up in the clear cases that the other cars come in. Don't really want them to be shelf queens but they will be protected as much as I can
Fathead59
Postby Fathead59 » Thu Aug 02, 2018 12:47 pm
I f you can Harry, when you are done doing your inventory of all the models I would like to get a list of them, e mail is LocoONE59@yashoo.com, thanks and happy slotting
Fathead59
Postby Austin » Thu Aug 02, 2018 2:34 pm
I used the Slot.it HRS2 Firebirds
Austin
Postby Fathead59 » Thu Aug 02, 2018 10:48 pm
I just picked up a RMS Camaro body from CincySlots, I am just wondering if it was a knock off or did Dave ever make a 67 Camaro body? Because looking at RMS I never saw a Camaro body. Because if he had I would have gotten one before he had to stop making them
Fathead59
Postby Fathead59 » Thu Aug 02, 2018 10:51 pm
And I want to say that I am sorry about that e mail address Harry , LocoONE59@yahoo.com is the correct address
Fathead59
Postby charlesx@xtra.co.nz » Fri Aug 03, 2018 1:29 am
Hi all.
Munter/John Warren has great range of resin bodies that he produces in NZ. They are reasonably priced and absolutely top quality.
Regards Chas Le Breton
charlesx@xtra.co.nz
Postby Fathead59 » Fri Aug 03, 2018 11:42 am
On a lot of RMS bodies Dave had different chassis that will fit the bodies , what I need to know if there is a web site that has the chassis in stock , the chassis I am looking for is a monogram chassis, if anyone knows of a web site that may have that chassis it would be a big help, thank you.
Fathead59
Postby dreinecke » Fri Aug 03, 2018 12:40 pm
Postby waaytoomuchintothis » Fri Aug 03, 2018 3:57 pm
One of your best, David.
Postby Fathead59 » Sat Aug 04, 2018 1:41 am
Well I was able to find one at a web site called Cincyslots, that was why I asked first if it was ever made at RMS first just to make sure it wasn't a knock off by someone else, that will be another car that will only be ran by me, and I did do one thing that I hoped will make sure that the bodies don't crack or break, use big wooden popsicle sticks and glued on the inside of the body, didn't seam to add much weight to it and I hope it strengthened it a little bit
Fathead59
