Just finished up another of my Pull back turned slot car rides. This one is a Marx 1/24 Lotus 24. Pretty good chassis detail on this one for a kids toy. I did the usual simple chassis in brass, with a Piranha motor, slotting plus guide, Slot it 27 tooth crown drilled for 1/8" axle. 9t pinion. tires are a mix of H&R fronts and my own rears. Color is ACE brand floro green, with clear over decals. I used a web picture of a real 24 that raced in this color and that number. Driver figure is resin cast by me
. I really lucked out on the period correct wheel inserts, as I was able to chuck the whole wheel from the pull back car in the dremel, and just spin them down till they were a press fit. Overall, this is one of my favorites so far. it handles great, and is plenty fast.
