Home Racing World • View topic - Chassis Mount
Chassis Mount
Chassis Mount
Postby Chunker88 » Mon Jun 18, 2018 9:09 pm
Finally soldered the chassis mount panels to my frame. I understand that a square piece of balsa is glued to the body in order to mount the body to the chassis? Help please. Oh. Following chassis build #5. Thanks
Chunker88
Re: Chassis Mount
Postby Broman62 » Tue Jun 19, 2018 8:01 pm
88…DO NOT USE BALSA!! It is way too weak to use as a chassis support!! Go to your local hardware or even paint shop and get/buy wooden paint sticks or a wooden yard stick...Harry did a piece on using the yardstick as his supports. They are both thick enough and strong enough to hold up and hold your chassis to your body with mounting screws!! Make sure to contour/angle the side you are gonna glue to the body as best as you can, too the contour/angle of the bodyside!! Good luck and welcome to the forum!!
Re: Chassis Mount
Postby mattb » Tue Jun 19, 2018 8:54 pm
You might make something from resin, if you don't do any resin, find some plastic you can cut a mount from. Fit the contour as stated above. put some holes where the mount fits against the body and scuff the inside of the body. Then epoxy it to the body. The holes give something for the epoxy to hold to.
I fit the mounts to the body and the frame, screw them to the chassis, put oversize wheels on and then glue the mounts.
Remove the screws and the chassis, put smaller wheels back on and maybe add some glue to the mounts while the chassis is off.
For some of the real wreckless guys, I drill a small hole and epoxy pins thru the side of the body and into the mount. I leave the pins exposed, but painted along with the body. Some of our guys try to tear down the track walls!
mattb
