That Hot Wheels looks like the "Lil Coffin" 32 sedan, definitely more radical than my effort.
Got some progress on modeling details.
Made some headlamp buckets from an airplane kit bomb and covered with a piece of .030" styrene hole punched. Positioned them low and attached with 1/16" brass tube through the rad cover.
Motor's paint detailed with a distributor made from 3/32" aluminum tube stuffed with wire stripped from a twist tie to resemble ignition wires.
Mocked it in place and the look is good.
Headers for the motor are next.
Turning out well.
