Home Racing World • View topic - Formula 1 Proxy Race?.............More Noodling.....
Re: Formula 1 Proxy Race?.............More Noodling.....
Postby Old23 » Mon Feb 19, 2018 9:35 pm
Allan,
Bravo for proposing a modern F1 Proxy Series. Of course, I have seen many historic GP Proxy races but never one for F1 cars from this century.
I have a number of Scalextric F1s from the era you have proposed, though nowhere near Alexis' collection of vintage 1990's Scalextric! I applaud your suggestion that a low-power motor become the spec motor of the series. Without magnets, the motors Scalex puts in these cars turns them into ballistic missiles. If the spec motor is to be a slimline FF can like the SCC Minnow, it should be a drop-in fit for recent Scalextric F1s. However, there is another issue. The Scalex releases prior to around 2004 were powered by the fatter FC-130 can. For instance, the Renault R23 #8 (C2398A) which models Alonso's 2003 championship-winning car, has the FC-130. Whereas, the Renault R24 #7 (C2581) that reproduces Jarno Trulli's ride from 2004 is the earliest car I own with the FF motor. All Scalextric "modern" F1's since then also have the slimline motor. The track width across the rear tires, shoulder to shoulder, is a touch under 58mm. Rear tire width on my cars varies from 11.5mm to 12mm, though I have replaced the stock tires with urethanes. The real F1 cars increased tire width and overall width for 2017. We'll have to wait and see if Scalextric's 2017 models (Williams and McLaren) follow suit.
I hope the above is useful.
Old23
Postby Beejay7 » Tue Feb 20, 2018 4:27 am
The 70's-80's cars from scalex were much stronger than the current crop, much less prone to damage and have the great benefit of being very cheap....why not use them with standard 18K motors. Everything else free choice.
Makes for good racing on our Club Track.
Beejay7
Postby Audi1 » Tue Feb 20, 2018 5:14 am
Postby Austin » Tue Feb 20, 2018 3:09 pm
This one OK only $39 preorder Scalextric
Austin
Postby chappy » Wed Feb 21, 2018 7:37 am
Looks a good car Austin. The thing with some of the cars is a difference in Wheels etc, even the newer ones such as the latest Lotus which had a extra long motor shaft, but the same motor and the Mercedes had smaller rims but bigger tires, but it all came out even in our club class. The benefit of using a less powerful motor is an advantage in control on these rocket ships. A very fun class to compete with. Open Wheel action and Paul Gage has tires for them too.
Postby Ky.Slot Racer » Wed Feb 21, 2018 8:53 am
all MT-SL motors have 12.70 mm - 0.050oo in. 1/2" long shaft from the outside end of the bushing housing.
Ky.Slot Racer
HRW Master Modeler
Postby chappy » Wed Feb 21, 2018 12:46 pm
Mark os that to show the longer shafted MT2 that would work in the Lotus.
Postby Brumos RSR » Wed Feb 21, 2018 1:23 pm
Thought the SL2 was no longer produced. Where would I pick those up?
Brumos RSR
Postby Austin » Wed Feb 21, 2018 3:11 pm
I would think the If SCC has a lot in stock
M/T-SL1 Slim Can Motor
Slim can FF-050 housing
Perfect NC1 type replacement for many makes using slim can type motor
Rated at 14,700 RPM @ 12V, 77.4 gcm
Great lower performing motor for Classic type cars
Will work in MRRC and some Scalextric cars using slim can motors
Allan I while ago I sent you a F1 setup this way, you still have it ?
Austin
Postby chappy » Wed Feb 21, 2018 5:46 pm
There are a pile of BWA ff050 and NC1 motors on epay by BWA at the moment .
Al Penrose has lots left if thats what you are looking for.
Postby Ky.Slot Racer » Wed Feb 21, 2018 9:53 pm
Last edited by Ky.Slot Racer on Wed Feb 21, 2018 11:33 pm, edited 1 time in total.
Ky.Slot Racer
HRW Master Modeler
Postby Brumos RSR » Wed Feb 21, 2018 11:07 pm
Brumos RSR
Postby Ky.Slot Racer » Wed Feb 21, 2018 11:31 pm
by god... I want to have a horse in this race, no matter the motor, and would also like to host a leg of it !!! on my woodie ...
Ky.Slot Racer
HRW Master Modeler
Postby Brumos RSR » Thu Feb 22, 2018 1:49 am
Perfect F1 track!!!
Brumos RSR
Postby chappy » Thu Feb 22, 2018 10:08 am
Thanks Mark. Can you give me the length of the shaft on the FF050.
Return to 2019 Formula 1 Proxy
Users browsing this forum: No registered users and 30 guests
