Home Racing World • View topic - Tire info
Tire info
Tire info
Postby vins123 » Fri Sep 08, 2017 8:05 pm
I would like to know if there are any silicone tire for the new Carrera Capri Zakspeed?
Sylvain
vins123
Re: Tire info
Postby mikeinclover » Sat Sep 09, 2017 6:47 am
I keep meaning to look at it, I forgot to check when it first arrived at the store, I will check today and let you know.
Mike
mikeinclover
Re: Tire info
Postby vins123 » Sat Sep 09, 2017 9:26 am
thanks
Sylvain
vins123
Re: Tire info
Postby vins123 » Wed Sep 13, 2017 8:19 pm
It will be for racing on a plastic track :D
vins123
Re: Tire info
Postby vins123 » Sun Nov 05, 2017 9:42 pm
What it would be silicone tire forthe new Carrera Capri Zakspeed?
Quick slick and Super tire?
thanks
Sylvain
vins123
Re: Tire info
Postby RichD » Mon Nov 06, 2017 12:48 pm
Both makes should work very well, There is a Super Tire for a Ford Capri (1309), I don't know if the Zakspeed uses the same tire. It would help if we knew the dimensions of the wheels, wheel diameter, wheel width, rib diameter, rib width and also the tire OD.
Re: Tire info
Postby Almafan 55 » Mon Nov 06, 2017 5:05 pm
Quick Slick tires for that car is CB32,CB33,CB34,CB35. Cloverleaf or SCC should have them in stock!
Almafan 55
Re: Tire info
Postby vins123 » Mon Nov 06, 2017 8:57 pm
vins123
Re: Tire info
Postby Cincyslots » Mon Nov 06, 2017 9:23 pm
That’s strange, the sut 1309 should fit the M1 and the Capri.
Bruce
Cincyslots
Re: Tire info
Postby Almafan 55 » Tue Nov 07, 2017 5:24 am
Oops, sorry, I misread your post. I thought you had sideways Capri. Forgot that Carrera brought them out.
Almafan 55
Re: Tire info
Postby vins123 » Wed Nov 15, 2017 4:58 pm
is anybody tried Super tire silicone 1308 on the Capri, an answer will be apreciated
thanks
Sylvain
vins123
Re: Tire info
Postby Cincyslots » Wed Nov 15, 2017 7:33 pm
I have not but the 1309 is nearly perfect to perfect.
Bruce
Cincyslots
Re: Tire info
Postby vins123 » Wed Nov 15, 2017 9:57 pm
vins123
Re: Tire info
Postby Cincyslots » Thu Nov 16, 2017 11:18 am
ok, the 1308 is not even close! Here are some photos to draw your own conclusion. I think the 1309 is fine.
Bruce
Cincyslots
Re: Tire info
Postby Cincyslots » Thu Nov 16, 2017 11:21 am
dang, I just saw you were after the Capri not the M1. I'll post more photos when I get more time.
Cincyslots
