Must be pretty old as the main body's not one, but five pieces.
Cleaned up the previously glued panel joints and re-glued it together. The result is quite a good looking classic roadster.
Not exactly great fitting seams so there'll be a bit of filing, sanding and filling on top. Will reinforce the seams underneath with epoxy to strengthen it.
Chassis-wise, I'll re-work this one constructed by another GVSCC member, Retro Racer44, who passed away almost a year ago.
Will make it adjustable to fit the longer wheelbase, add side pans and do a general clean up.
