Home Racing World • View topic - Cutting Carbon Fiber
Postby ddyke » Sun Feb 17, 2013 7:32 am
I asked on the hobbyist machining board on how to cut carbon fiber. This was the answer I got:
"Composites are very tough on bits. I would suggest a carbide diamond cut router bit, the type they make for circuit board work. If you are going to be cutting a lot of it then it would pay to get the ZrN coated bits. Take a loot at: http://www.soigeneris.com/precisebits_d ... tails.aspx (my web site). A good starting point is to feed 1IPM per thousand spindle RPM, for example 10,000 RPM spindle feed at 10IPM. A 1/16" bit can cut through 1/16" FR4 (fiberglass) in a single pass."
Maybe this will help.
ddyke
Re: Cutting Carbon Fiber
Postby ddyke » Sun Feb 17, 2013 7:41 am
ddyke
Postby bill from nh » Sun Feb 17, 2013 10:02 am
I don't work with carbon fiber, but if I did, these bits might be a good way to machine it. The individual bit prices are reasonable, but with a $50 minimum order, it would be best to place a group order.
bill from nh
Postby 4424ever » Sun Feb 17, 2013 10:43 am
how would the diamond coated bits work in this case!
4424ever
Postby RazorJon » Sun Feb 17, 2013 11:40 am
are you using a router or a milling machine?
Postby ddyke » Sun Feb 17, 2013 12:22 pm
The guy was recommending it for the mill. My mill is variable speed.
ddyke
Postby RazorJon » Sun Feb 17, 2013 1:16 pm
Postby ddyke » Sun Feb 17, 2013 1:21 pm
I found one in a grab bag of PC board bit I got at Woodcrafters a long time ago. I tried it. It cut real nicely until I got to the last 1/16" and then a strip of the fiber came up and pulled away.
ddyke
Postby FootScoot » Mon Feb 18, 2013 7:57 am
Just a word of caution when working with carbon fiber materials, especially anything involving cutting or machining wear eye protection, protective clothing and a respirator. Carbon fiber dust or shards are extremely bad for you body. I got this info straight from a friend who works with it everday at BAE in the UK. He says it's just nasty stuff. :)
Postby ddyke » Mon Feb 18, 2013 7:59 am
Good warning. I have decided it is not worth it for weight savings but on for reinforcement which means minimal cutting.
ddyke
Postby Foamy » Mon Feb 18, 2013 11:48 am
If you are just cutting plates, just use a dremel and cutoff discs. I made lots of R/C chassis way back in the early/mid 80's that way.
Foamy
Postby ddyke » Tue Feb 19, 2013 5:51 am
On dangerous materials you can keep a running shopvac's nozzle close to your cut to suck up the powder as the piece is being cut. A few short strips can strengthen a plastic chassis immensely.
ddyke
Postby FootScoot » Wed Feb 20, 2013 7:19 am
I've used it for reinforment on chassis', the smaller thin stuff. I just mark it with a silver pencil and cut it under running water with a razor saw. No dust, no fuss. A shop vac would work as well, I just don't have one. Yet another excuse to go to Menard's. :)
Return to SlotCar ToolTime
