McLaren M1B
For 1/32nd Scale Models
McLaren M1B
Postby BARC 1 » Sat Aug 05, 2017 11:29 am
Finally found some time to build some slot cars. First out of the Gate is a McLaren M1B Can Am car. Chassis is Brass plate and Lego with a Dual can motor set up giving me space for a full interior. Car is resin casting, and I think the decals are from Pattos. Found them in my decal drawer.
Re: McLaren M1B
Postby HomeRacingWorld » Sat Aug 05, 2017 11:47 am
Dual can motor setup?
Re: McLaren M1B
Postby BARC 1 » Sat Aug 05, 2017 1:26 pm
The Dual Can or Twincan was used to help boost the torque from the small can motors I use on these cars. If you remember the Porsche 911 I sent into the Brass am, it had a single can motor.
On my small home track this set up is ideal, and produces a very balanced car to drive. These motors only turn 16K at 12 volts, and when run at 10 volts there are really anemic, and as a result the proxy car Porsche 97 I have running in the TransAm is battling to stay out of last place. Twining the motors has increased the acceleration, but unfortunately the 16K is still 16 K so the top end is not there for proxy racing.
Again though with my home track and straight limited to 11 feet, I get lap times that are almost equal to Cars with 21K 130 can motors.
The chassis is a gift card with a brass plate. Axle blocks are Lego. The rear blocks have 3/32 bearings, and the result is a free rolling chassis.
Re: McLaren M1B
Postby HomeRacingWorld » Sat Aug 05, 2017 1:52 pm
Interesting. And tune it so it works for you, that's all that matters. Well done.
Re: McLaren M1B
Postby munter » Sat Aug 05, 2017 1:54 pm
Like
munter
Re: McLaren M1B
Postby dge467 » Sat Aug 05, 2017 3:23 pm
Nice work!!
Re: McLaren M1B
Postby waaytoomuchintothis » Sat Aug 05, 2017 7:01 pm
Yep. That's a unique version of dual motoring. Its surprisingly easy to do a dual inline motor successfully, and these early CanAm cars are perfect for it. I did a Mercedes 196 with dual NSR motors (much more crowded than a CanAm), set up counter rotating with independent rear drives for the Land Speed Record at Bruce's place in Cincinnati years ago. I think I came in third, but that was a long time ago, and I was close to passing out the entire time... heat, guys, heat! Cincy is the capital of the finest pork, over 100% humidity, and insane levels of summer heat. There was no beer at the meet. Good thing.
Re: McLaren M1B
Postby dreinecke » Sat Aug 05, 2017 7:10 pm
Nice looking McLaren and that motor setup is very cool!
Re: McLaren M1B
Postby CJR » Sat Aug 05, 2017 10:22 pm
Great looking!
CJR
Re: McLaren M1B
Postby BARC 1 » Sun Aug 06, 2017 1:26 pm
After the first set of pictures I found the mirrors needed to be reworked
Return to 1/32 Showcase
